Android Tablet / Anan Mobile
Posted: Fri Jul 04, 2025 10:57 am
by Ken
I hope this is a good place to start this post.
Anyway, Happy 4th of July! (2025)
In the far distance past when SDR radios were just starting up, for the most part, and the Anan SDRs weren't created yet, I had built a small PC with a mobile
12 volt input power supply all in a modified case to fit under a bench seat in a pickup truck. I used a 10 inch 12 volt monitor that I installed on a dash mount.
I was using a Flex3000 in the truck for the reason for the Mobile PC. At the time, I knew of no one who was doing this, so it was all unknown territory and experimented event
in which I had enjoyed.
My question if you please, has anyone installed a SDR ANAN in a vehicle using an Android tablet? Is there any software for this type of operation?
I suppose I could buy a Window tablet, but would there be a hardware connection on either type of tablets? I have seen a USB type of connection for a monitor connection, as well
as a network connection.
Is there anyone here who has done this already?
Thank you for your time.
Ken
Re: Android Tablet / Anan Mobile
Posted: Sat Jul 05, 2025 1:24 am
"Microphones..." sub-forum is not a good place for this :D
I will be moving it to "PC's & Homebrew Hardware".
There is no Android-based solution available.
The good news is that you've already done this with a Windows PC and a Flex-3000. You can take the exact same approach with an ANAN, except that the connection will be via Ethernet.
Posted: Sat Jul 05, 2025 3:18 pm
by laurencebarker
There is an android app from John Melton G0ORX/N6LYT: it is called OpenHPSDR Radio. I found this link: https://openhpsdr.en.aptoide.com/app
I know no more that that!
Posted: Sat Jul 05, 2025 9:26 pm
by Ken
Very good on moving it, my apology please.
And thank you Laurencebarker for your response.
Both of you are appreciated.
Ken
Posted: Sun Jul 06, 2025 12:59 am
by KA1GXR
Last I knew that Android app will not work with Thetis. I used to use it.
Tom
KA1GXR
