anan 7000dlemk2 black edition tvtr set up
Posted: Fri Aug 01, 2025 11:58 am
I need some help setting up a q5 2m tvtr to my anan 7000dle mk2 black face, I have wired it up same as the previous owner of both units had it (split if) and have enabled tvtr in thetis for 2m and put 116 in the mhz offset column. But still no rx signal. I have the sma tvtr output on the 7000 going to the q5 tvtr and the receive path from the tvtr is goIng to tvtr rx bnx socket on the 7000 for the return rx path. I think there is something in thetis set up to enable split IF possibly which I cannot find (otherwise how would the 7000 know that the tvtr was not a single if using the sma connection only. the set up was working fine two days ago when I tested it at the qth of the previous owner of the 7000 and the conntected q5 tvtr so I am assuming its something i need to set within thetis new install to tell the 7000 that I am using split if?
Steve gw0gei
Steve gw0gei
