26 pin J16 Acc Connector
Dan
Post by Dan »
Does anyone know if this cable is compatible with the 26-pin J16 ACC connector on the back of the 10E?
Thank you, Dan
https://www.amazon.com/Antrader-Connect ... r=8-6&th=1
Screenshot 2025-08-04 at 21.54.29.png (297.68 KiB) Viewed 779 times
Re: 26 pin J16 Acc Connector
That should work.
Dan
Post by Dan »
w-u-2-o wrote: Tue Aug 05, 2025 1:42 pm That should work.
Thanks, it worked just fine.
