Drive/Multi Knob on G2V2 Front Panel
chuckgreen29@gmail.com
I am currently running Thetis x.10 and find the knob marked Drive/Multi is programmed differently than the other knobs. All other knobs use the outermost knob to control the first named function. For the Drive/Multi knob the larger knob closest to the panel controls the Drive. Consistency would be appreciated. I can't tell if this is a Thetis or G2 action item, but I thought I would mention it in case the correct person will fix this anomaly.
laurencebarker
Re: Drive/Multi Knob on G2V2 Front Panel
you can use the Thetis "edit controls" function to swap them around, if you want.
The multi control needs the use of the pushbutton to change its assigned function. If you assigned multi to the outer encoder, you'd still need to press the button on the inner one.
Thank you, Laurence. I did not know either of those 2 points. Perhaps the panel labeling should be different. I will have to learn the features/options of the multi control. I did not know an "Edit Controls" existed. Thank you for the informative AND useful reply.
Chuck AD4ES
Chuck AD4ES
