G2V2 Interface with New Expert 1.5k Taurus
Posted: Sat Aug 09, 2025 4:57 pm
Now that the Taurus is available, I am considering purchasing one for my G2V2. My interface plan is as Follows:
My plan is to use a USB connection to communicate with the amplifier and 4 open collector outputs for band information to the amp. A 5th open collector will provide a power up signal to the amplifier when the G2V2 radio is on. I'd run a PTT line from the G2V2, through my Steppir controller to the PTT amp input and I think that should do it. I would use the PA settings on Thetis to limit the drive power to the required level to obtain max legal power output.
Does anyone know if this is a viable approach or if there is an easier or better approach?
Comments welcome as I cannot find any posts regarding this interface.
Chuck Green AD4ES
Chuck Green AD4ES
