Distortion When Using Voicemeeter Potato and Thetis
n2gq
Post by n2gq »
Distortion When Using Voicemeeter Potato and Thetis and a Presonus 68c.
The buzzing sound is on audible when using voicemeeter potato. If I just use Presonus studio 68c and CM audio route and set the driver "Studio USB ASIO Driver" all is fine. Started sometime this year but did not have time to deal with it.
Equipment is as follows:
Anan-7000del mkIII
Presonus 68c
Windows 11 pro 24H2
Jay N2GQ
n2gq
Re: Distortion When Using Voicemeeter Potato and Thetis
Post by n2gq »
It seems to happen when I open an app over the Thetis window. Spectral warning Leds go red and the other yellow. Maybe related to display somehow.
Jay N2GQ
Jay,
You haven't given us any information at all about your Thetis configuration or your Voicemeeter configuration or your computer configuration (including hardware and all of the apps you have running while you're experiencing the buzzing).
Without any of that information there's no one here who can help you determine what the problem is.
n2gq wrote: Mon Sep 08, 2025 12:16 am It seems to happen when I open an app over the Thetis window. Spectral warning Leds go red and the other yellow. Maybe related to display somehow.
This is the critical bit of information that was missing.
The problem is that your CPU is not keeping up with the real-time requirements of the spectral display, and apparently not the audio stream, either.
Lower your spectral display update rate to the point where nothing you do on the PC at the same time as running Thetis causes the red or yellow indicators on the spectral display.
The Vsync option should automatically sync Thetis to the Windows defined display update rate (typically 60Hz, sometimes 30Hz, etc.).
Just out of curiosity:
- What is your current display update rate in Thetis?
- What is the display update rate set to in Windows?
- What does your CPU load look like? Use Task Manager, Resmon or Process Explorer, do not use Thetis to measure this number.
- Have you confirmed that the Presonus is running at 48KHz using the Presonus Universal Control app?
- Have you assigned the Presonus as the A1 hardware output in Voicemeeter?
- Are all Voicemeeter devices listed in the Windows Sound Control Panel > Advanced Properties explicitly set to 48KHz?
n2gq
Post by n2gq »
Here is config. AMD Ryzen 9 5900XT 16-Core Processor (3.50 GHz) 64gb ram
thetis display config.png (6.23 MiB) Viewed 5359 times
thetis display config 2.png (337.32 KiB) Viewed 5359 times
config for potato.png (4.24 MiB) Viewed 5359 times
Jay N2GQ
Step 1: While your monitor might happily run at 144 frames per second, the "real-time" code in Thetis almost certainly won't. If your monitor really is running at 144Hz (nice gaming monitor?) you might try 72Hz in Thetis (half the monitor rate). 60Hz is certainly more than adequate to achieve a smooth spectral display. Even 30 works well.
BOTTOM LINE: you want NO spectral warning indications, EVER.
Step 2: use cmASIO to connect to Voicemeeter. Then you don't need to worry about any VAC settings and latency will be as low or lower than any other method.
With the excellent Presonus interface, and that ripping fast Ryzen 9 16-core processor, once you do the above two steps you should have near ZERO problems with audio and RF signal quality.
Thetis likes a lot of cores, which you have, doesn't need a ton of RAM, which you have, and doesn't care about mass storage speed. Nevertheless, because all the Thetis DSP is done in the CPU, as opposed to the GPU, it is all too easy and tempting to run too high a frame rate with modern, high refresh rate, gaming monitors.
n2gq
Post by n2gq »
So far, the refresh rate 30, 60 or 144hz made no difference. Then I turned off re-size bar and reduced resolution down to 1440p (2k) from 2160 (4k) And that stopped the problem. This only happens when using potato.
Jay N2GQ
n2gq
Post by n2gq »
- What is your current display update rate in Thetis? 144
- What is the display update rate set to in Windows? 144
- What does your CPU load look like? Use Task Manager, Resmon or Process Explorer, do not use Thetis to measure this number. When it buzzes still look normal, no excess load
- Have you confirmed that the Presonus is running at 48KHz using the Presonus Universal Control app? Yes 48khz
- Have you assigned the Presonus as the A1 hardware output in Voicemeeter? yes
- Are all Voicemeeter devices listed in the Windows Sound Control Panel > Advanced Properties explicitly set to 48KHz? yes all 48khz
Jay N2GQ
n2gq
Post by n2gq »
n2gq wrote: Mon Sep 08, 2025 6:33 pm Hi,
Distortion back for a shorter time using 1440p and re-size off. So not a solution.
Going to try sonar if possible. Don't know if sonar is porting asio.
Jay N2GQ
Are you using cmASIO?
Something else is wrong. The size of the Thetis window and the resolution of the monitor should not matter. For instance, I can set the Thetis window to appear across all three of my triple 4K displays and it has no problem with either VAC or cmASIO with Voicemeeter. I'm also using a Presonus interface.
Try reinstalling Voicemeeter. Don't forget that requires the following sequence: uninstall, reboot, install, reboot.
Try updating your video drivers.
n2gq
Post by n2gq »
w-u-2-o wrote: Tue Sep 09, 2025 12:19 am Are you using cmASIO?
Going to re-install Potato.
Re-installed but same noise.
Jay N2GQ
Have you tried updating your video drivers?
n2gq
Post by n2gq »
w-u-2-o wrote: Tue Sep 09, 2025 7:38 pm Are you using cmASIO?
Yes, I went to AMD downloaded drivers for RX 7800xt card uninstalled restart and then installed then a restart.
Did the same for Voicemeeter had to be careful uninstalling because sometimes you have to regen a new challenge code for license. Same results
Also did the same for Presonus universal control as well as changed the device to a studio 26c just less channels. Same results.
Removed display port cable used a hdmi cable same results.
When I look at task manager all looks ok. I even tried setting app priority no change as well.
As long as I have a window that is not maximized all is ok. But while Thetis is running and I max out a window the noise comes back.
Will keep looking.
Jay N2GQ
n2gq
Post by n2gq »
A better video explaining problem.
Jay N2GQ
Trucker
Post by Trucker »
That is odd. Is it noticeable if you have noise reduction turned on?
sv1jso
Post by sv1jso »
Check background task priority under power settings or related power settings.
n2gq
Post by n2gq »
sv1jso wrote: Wed Sep 10, 2025 9:09 pm Check background task priority under power settings or related power settings.
Thetis priority is set to high and voicemeeter is set to normal. I tried changing them but made no difference. Presonus is also normal.
Jay N2GQ
n2gq
Post by n2gq »
Trucker wrote: Wed Sep 10, 2025 8:30 pm That is odd. Is it noticeable if you have noise reduction turned on?
Yes, sounds the same. Going to try using another Voicemeeter ASIO name. Well, that did not work.
Jay N2GQ
Trucker
Post by Trucker »
Does it do it if you disable the connection to Potato and just route the audio through the Windows System/Sound settings? That might reveal if the problem is with settings in Potato or how you have setup your cmASIO driver in the Registry.
n2gq
Post by n2gq »
Trucker wrote: Thu Sep 11, 2025 1:24 am Does it do it if you disable the connection to Potato and just route the audio through the Windows System/Sound settings? That might reveal if the problem is with settings in Potato or how you have setup your cmASIO driver in the Registry.
Yes, if i use presonus ASIO driver directly without potato there is no problem. In the registry i use "voicemeeter virtual ASIO" if I use potato.
Jay N2GQ
Trucker
Post by Trucker »
Having only tested Potato a few times myself, I would think that you would still be able to route your audio to Voicemeeter Potato and still continue to use the Personus ASIO driver. And that you wouldn't have to use Voicemeeter's virtual ASIO driver.
I could be wrong about that. But, I think I have read a post in the forums about this very thing. ( not necessarily the effect you are hearing)
Trucker
Post by Trucker »
Scratch my comments about not using Voicemeeter Potato's ASIO driver. ( it's getting late) I think you have a problem with a Voicemeeter Potato setting somewhere. Especially if everything works correctly when you use just the Personus ASIO driver. Hopefully, someone more experienced with Voicemeeter Potato can chime in and help you figure this out.
n2gq
Post by n2gq »
Trucker wrote: Thu Sep 11, 2025 5:02 am Scratch my comments about not using Voicemeeter Potato's ASIO driver. (it's getting late) I think you have a problem with a Voicemeeter Potato setting somewhere. Especially if everything works correctly when you use just the Personus ASIO driver. Hopefully, someone more experienced with Voicemeeter Potato can chime in and help you figure this out.
Hi James,
I was thinking the same thing and routing Presonus through voicemeeter instead. But one of the first things I am going to do is re-install Thetis. I am wondering if this problem started when I swapped out the processor in the early spring.
Jay N2GQ
n2gq wrote: Thu Sep 11, 2025 1:21 pm
What does that mean? If you are bringing Voicemeeter into the configuration, and using cmASIO (which it appears you are), then there is no choice but to have the Presonus routed through Voicemeeter (unless you are listening via speakers/headphones on a "normal" Windows sound device, but why would you do that?)
Assign the Presonus main L/R out (presumably attached to some speakers or studio monitors) to Voicemeeter hardware output A1. Assign a Presonus mic input to Voicemeeter hardware input A1. Assign Thetis/cmASIO to "Voicemeeter Virtual ASIO" which corresponds to virtual input and output B1. Mix and route in Voicemeeter as required.
Also, you might review the cmASIO instruction sheet that can be found as a PDF in C:\Program Files\OpenHPSDR\Thetis. In that document it states that "ASIO driver must be able to operate under the following conditions", which are:
- 48,000 sa/s sampling rate (you've already confirmed the Presonus is set to this)
- 64 sample buffer size (set this in the Presonus Universal Control app)
- Int32LSB sample format (24 bit samples, left aligned in 32 bit little-endian integers) (set this in Voicemeeter).
Finally, going back to your original post, whatever you do, you must not see any spectral warning indicators in Thetis. They represent the kiss of death for audio quality.
n2gq
Post by n2gq »
w-u-2-o wrote: Thu Sep 11, 2025 2:01 pm
My thoughts were routing a different way through Potato but and Presonus Audio but don't think it would work. I tried a new Database didn't work. I tried all of suggestions above. Going to try my other computer with the processor I had here a 6 core which work just fine before I swwitched to 16 core.
Jay N2GQ
n2gq
Post by n2gq »
[/quote]
[/quote]
The other computer had the same distorted audio :o .
Jay N2GQ
That's a big clue.
How is the Ethernet connection configured? PC direct to 7000? Or through a switch?
n2gq
Post by n2gq »
w-u-2-o wrote: Thu Sep 11, 2025 11:52 pm That's a big clue.
I have it connected to a dedicated network card on the main shack computer. The other computer I had it connected to it's network card as well. I never used the switch method.
Jay N2GQ
We are down to grasping at straws here.
You might try optimizing your NIC configuration as discussed in this topic: viewtopic.php?t=4127
Also, double check that the connection is running at 1 Gb/s (assuming you are using Protocol 2 firmware).
n2gq
Post by n2gq »
w-u-2-o wrote: Fri Sep 12, 2025 2:17 pm We are down to grasping at straws here.
I followed nic config suggestions on W1AEX site and I believe some of yours back when I purchased radio.
Jay N2GQ
