Anan G2 Ultra RX
Posted: Sun Sep 21, 2025 10:34 pm
I recently received my Anan G2 Ultra. What I am finding is I need to leave the attenuator on -30db or else I get constant ADC overloads. When I do this, all the weak signals disappear. I do a side by side with my FTDX-5000 ( same antenna with a switch going between the two radios ). The 5K pulls these weak signals in no problem, the G2, def. On the G2, if I set the attenuator for -20db, I hear these signals a bit closer to what the 5K is doing, but then I'm back to the ADC overloads ( flickers between yellow and red ).
On the G2, I have played with the AGC, but other than changing the background noise or making signals go away, it does not affect the ADC overloads.
Where else do I need to look?
