G2 Ultra front panels stops working after piHPSDR upgrade
Posted: Thu Oct 23, 2025 7:40 pm
by laurencebarker
We have discovered recently that the piHPSDR upgrade process can stop the G2 Ultra front panel from working. See this thread: viewtopic.php?p=32383#p32383
Christoph has removed the file causing the issue from the piHPSDR repository, because the correct one is already in the Saturn repository.
If your front panel stopped working after piHPSDR upgrade, there is a simple "fix" that only needs to be done once.
Open a terminal window and type the following:
cd ~/github/Saturn/rules
sudo ./install-rules.sh
And that's it!
