2wks and counting I have been unable to use my Anan 7000 DLE MKII
I’ve recently run into an issue where I can no longer connect to my ANAN-7000DLE MKII.
For several months the setup worked flawlessly:
Starlink providing internet
Starlink Ethernet → unmanaged 5-port switch
One Ethernet from the switch to the PC NIC
One Ethernet from the switch directly to the ANAN
The ANAN was always discovered instantly by Thetis and operated normally.
At some point (no hardware changes that I’m aware of), the ANAN stopped being discoverable and I can no longer connect to it.
What I’ve tried since:
- Removing the switch and connecting the ANAN directly to the PC NIC
- Resetting Windows network settings
- Assigning static IPs on both the PC and ANAN (same subnet)
- Disabling Wi-Fi and firewall for testing
- Trying multiple Ethernet cables
- PC NIC works normally (can ping its own IP)
- Ethernet link lights are present on both the PC and ANAN
- ping to the ANAN IP fails (destination host unreachable)
When placed into bootloader mode, the ANAN shows green LEDs and the Ethernet link comes up, suggesting the Ethernet hardware itself is OK
At this point it feels like either:
A firmware / network stack issue on the ANAN, or
Something subtle I’m missing in the network configuration
Questions:
Has anyone seen this behaviour before?
I have flashed loads of different firmware versions without fail with HPSDR bootloader, the radio will simply not work.
I've tried static IP's and DHCP and nothing is working.
Hardware fault?
Any advice would be greatly appreciated.
