WSJTX FT8 no PTT
Posted: Fri Jan 09, 2026 7:41 pm
by qst
I configured WSJTX for FT8/FT4 operation. I used the VB-Audio virtual ports. I used a pair of CAT ports. The CAT test is OK, and the PTT test lights red, but it doesn't toggle PTT. Maybe I configured something incorrectly. I just don't know if I need to enable PTT in Thetis or in WSJTX?
Re: WSJTX FT8 no PTT
Posted: Fri Jan 09, 2026 8:17 pm
By CAT ports, do you mean you used virtual serial port software?
You need to enable CAT PTT in WSJT-X.
I recommend you use TCP/IP CAT instead of virtual serial CAT. I posted this in your other topic: viewtopic.php?p=32632#p32632
Posted: Sat Jan 10, 2026 9:12 am
by qst
Thanks for the help. FT8 is working fine. Problem solved. 73's
