discord server
Posted: Fri Feb 06, 2026 3:18 pm
by Joel1
Did something happen to the discord server? I haven't checked things in a while, when I log in to look, Thetis is missing from my account. When I try to rejoin, I get a message about not being able to accept the invite.
Anyone know if there's an issue?
Joel
Re: discord server
Posted: Fri Feb 06, 2026 4:39 pm
You probably got caught up in the recent rule change about nicknames:
Important: Rule No. 1 (Server Nickname & Callsigns)
All members must ensure their server nickname follows the name/nickname convention in Rule No. 1.
If you have a callsign, it must be included in your server nickname. If you do not have one or wish to keep it private then use your name/nickname with [SWL].
When is this happening ?
On 1st February '26, any member who is not compliant with the naming convention in Rule No. 1 will be removed from the server. Any user removed will be able to re-join via a normal joining link as long as the name/nickname convention is followed.
Re: discord server
Posted: Fri Feb 06, 2026 7:46 pm
by Joel1
I am not sure of what you are describing. say my username/login name is xyz, what do I need to change it to?
Re: discord server
Posted: Fri Feb 06, 2026 8:44 pm
Allow me to repost, again, the same message that Richie posted to all his Thetis Discord users (and that you should have also received by email). I'll add some additional highlighting for you:
Reading is fundamental
