Epic ongoing BATTLE with Singaporean botnet; UPDATE #1 posted
Posted: Tue Feb 10, 2026 7:09 pm
All,
My apologies for the interruptions in service, but the board is currently engaged in an epic battle with a botnet or other bad actors located in Singapore.
Whatever their goals it has essentially amounted to a denial of service attack.
The board had reached 300,000 :o guest users and ground to a halt.
I have enabled a much stricter IP address block list, but now that total is only down to 37,000!
At this point I'm going to have to block the entire IP range of Singapore. My further apologies to any members who might be located there. All I can tell you is that you may wind up having to use a VPN to overcome that geo-restriction.
More to follow as the battle progresses...
Re: Epic ongoing BATTLE with Singaporean botnet
Posted: Tue Feb 10, 2026 11:25 pm
Update #1: making some progress.
I've got the number of established connections at the firewall output down to < 100, and the number of page pulls in a 1 minute period to < 300. The AIs tell me this is pretty good.
You can see where the attack started on 9 Feb. We are now headed into the 20th hour of the attack and it continues unabated.
I now have to make the changes to the firewall (iptables) persistent across reboots, create scripts for the blocklists to auto-update, and I think that I will add country blocking for both Russia and China as well.
The bots tend to make between 6 and 8 simultaneous connections to the forum per IP address. I will also probably modify the web server to limit it to 4.
As this is not my "day job" it's probably going to take me another two or three days to get this done.
The battle continues!
Re: Epic ongoing BATTLE with Singaporean botnet; UPDATE #1 posted
Posted: Wed Feb 11, 2026 1:05 am
by KA5KKT
