Thetis Remote Operation With 2.10.3.13 dev3c
Posted: Wed Feb 11, 2026 3:10 pm
With the new network setup options Richie added in the latest .13 dev3c release, I now have my G2 running as a server at my home QTH in Apex, NC, and I’m remoting into it from my work QTH in Asheville, NC. So far, it has been absolutely flawless.
Performance has been every bit as solid as my old 6400/Maestro setup. Both locations are on AT&T 1-Gig fiber, patched through a few unmanaged switches. I honestly can’t believe how well this is working. I haven’t experienced a single glitch or RX artifact, and the panadapter/waterfall is smooth as silk. On transmit, I’ve received excellent audio reports so far.
I’m not sure whether upgrading the G2’s Pi to a Pi 5 and running Trixie (thanks, Jerry!) has made a noticeable difference—I never tried this on a Pi 4—but the extra processing capability certainly isn’t hurting anything.
I’ve kept the audio chain simple: just a USB mic, no CMASIO, using the Windows WASAPI driver.
If you’re interested in trying remote operation with your ANAN and Thetis, Richie has provided a few files that outline the correct ports to forward on both ends. You’ll also need to join the Discord channel and access the development section to obtain the latest dev releases (participation and testing feedback are expected).
Based on how well this is working, I’m hopeful—and confident—that these new network options will make it into an official release before long.
