New 7000 and 1st post--
Running HPSDR mRX and not able to find the CPU meter. I haven't seen anything in the user manual or in the forums as to how to get this to come up. I keep right/left clicking on the date/time/volt meter but nothing happens their.
Thank You
Larry
N7ZDR
													Wheres the CPU Meters?
									7000 mkll Thetis v2.8.11 21k3
P2_v2.0b
						P2_v2.0b
Re: Wheres the CPU Meters?
I believe it was either CPU or another function set in settings, but most of us have switched to Thetis as it has a lot more features and performance.
There's nothing you need to do for it to show. It simply is there, right under the time display.
What version are you running? Maybe you need to uninstall/reinstall it?
In the Display Tab, General, Right side uncheck the block labeled "Show Volts/Amps"
If "Show Volts/Amps" is unchecked and CPU is still missing try the procedure from W1AEX. http://www.w1aex.com/anan/anan.html#counters
Thanks All-- up and running and showing 6-7 %
This is a new set up with new PC after owing Flexes for the last 6 years (I can't believable what I am hearing as the NR is awesome)
As far the Thetis----- it looks awesome but it's to scary to attempt to give it a try
I have been slowing reading about the procedure but still not quite sure of my self yet-- kind of like a little baby (little steps at a time).
With a little persuasion will give it a go!??
Thank You
Larry
N7ZDR
Thank You
Larry
N7ZDR
P2_v2.0b
						P2_v2.0b
It's easy and many of us are enjoying all the new features and efficiencies that Ritchie has brought to 2.7.0. The latest firmware for the 7000 is 2.0bLarryW wrote:
There is no looking back when you start using Thetis 2.7.0, almost like going from a Flex SSDR to PowerSDR (been there, done that).
Gary-----Why on earth did you say that? The suspense is killing me , what is a man to do now?
Where is the best location/place to get the most pain free instructions for a old guy like me living in a little remote cabin in Idaho?
Gary, if I fail and the rig starts smoking out the back you will need to fly to central Idaho and make any needed repairs. Lodging and black Angus steaks will be provided for up to 2 nights stay
Larry
 Larry
P2_v2.0b
						P2_v2.0b
Not trying to be a jerk here but this forum is THE place to get all that info, all very well documented. But I'll give you a few quick shorcuts.
Get Protocol 2.0b here https://apache-labs.com/community/viewt ... =32&t=3192
Get Thetis 2.6.9c3 Installer here https://github.com/w5wc/Thetis/releases/tag/v2.6.9
Get the drop and replace 2.7.0a3 Thetis files here https://apache-labs.com/community/viewt ... f=9&t=3345
But read these 2 threads to see all the new features and ways to enable them. Start with this thread first:
https://apache-labs.com/community/viewt ... f=9&t=3182
And finish with: https://apache-labs.com/community/viewt ... f=9&t=3345
Only the 2nd day with the new 7000-- but have been reading this forum for about 2 weeks so I know it all the info is here somewhere.NC3Z wrote:Not trying to be a jerk here but this forum is THE place to get all that info, all very well documented. But I'll give you a few quick shorcuts.
Your post will point me for sure in the right direction--- Thank You.
Only on rainy days can I play radio- all other times are devoted to placing and/or checking bear traps and babysitting hunters who pay me lots of money so they can hunt/see or take a picture of Idahos abundant Canadian gray wolves.
Larry
P2_v2.0b
						P2_v2.0b
