Waterfall level setting
vk6cpu
Post by vk6cpu »
I'm currently running Thetis v2.7.0 (a3).
I used to be able to set the level of the waterfall display by clicking and dragging on the left hand side of the spectrum display.
Has this facility been removed in the latest versions OR have I turned off the option somewhere ?
I've been through all the tabs on setup and so far drawn a blank.
All the best
Nigel
VK6CPU
INTEL i9 12900 64.0 GB Ram
PD3LK
Re: Waterfall level setting
Post by PD3LK »
Hi, when i uncheck this box then it doesn't work for me either so i think this is what you are looking for.
73, PD3LK
rbduck
Post by rbduck »
All right you have my attention. Where exactly on the left side of the spectrum display are you clicking and dragging? I was unaware the waterfall display level was adjustable this way. Thank you.
PD3LK
Post by PD3LK »
When you drag the spectrum up or down then the waterfall gain can follow this way.
rbduck
Post by rbduck »
Perfect! That works. Thanks!
vk6cpu
Post by vk6cpu »
Thanks Leon!
That works for me too!
Problem of my own creation solved! :D
All the best
Nigel
VK6CPU
