2.7.0
Re: 2.7.0
Hello Marcus,
this is the trick! Thank you for this hint! Now I am waiting for a reply to my second problem with the Filter tab...
73 de Georg, DG9FDA
73 de Georg, DG9FDA
Anan 100D first edition, Thetis v2.10.3.6 x64, Protocol 2 Version 12.1.8
						Re: 2.7.0
Hi Georg,
remember to utilize DDUtil v 3.2.5 and connect your radio to your computer & the amp to your computer (as explained in the amp manual) so you can automatically control your drive level in Thetis by band. So you never overdrive your 1K-FA.
I've been utilizing this procedure since I got my Flex 5000A almost 10 years ago. DDUtil is to be downloaded on k5fr.com. It works for legacy Flex radios and has always been good for Anan radios operated thru PowerSDRmrx or Thetis. Later versions after 3.2.5 do not work being only suitable for Flex signature radios (6000 series).
Maybe you already use this configuration. If not I could give you a hand to fix it if needed.
73s Phil FM5GB
73s Phil FM5GB
Re: 2.7.0
Thank you Phil,  I will try when I find the time...
73 de Georg, DG9FDA
									73 de Georg, DG9FDA
						Re: 2.7.0
2.7.0a3 is here.... https://www.dropbox.com/s/8ik72kfeqycex ... 3.zip?dl=0
unpack the files into your Thetis installation map. (overwriting the 2.6.9 files)
Don't forget to make a backup before doing this.
73 PD3LK
73 PD3LK
						Re: 2.7.0
From my knowledge, these are the most recent sources.
https://github.com/w5wc/Thetis
						Re: 2.7.0
Where is the latest firmware for Thetis 2.7a3? Is there a list of fixes the different firmware versions address?
Dave
k4em
						Dave
k4em
Re: 2.7.0
Easiest way to find them is to go to the firmware discussion:Dave30019 wrote:Where is the latest firmware for Thetis 2.7a3? Is there a list of fixes the different firmware versions address?
						Re: 2.7.0
Go to the section Upgrading/Downgrading and read the first topic. It contains links to the firmware areas.
