Out of sequence packets... Received the -ve icon
KC1LKO
Post by KC1LKO »
Hello. Hope this is the right place to report these... Let me know.
Running 2.8.9 with P2
Assuming firmware is 2.0 and not 2.0b ? The setup-general-HWselect screen shows ver 2.0 Right above the OrionMkII ID
Received the -ve icon (yellow triangle inside red box) in status bar. Clicked and below is the text:
Code: Select all
DCC0
s0=0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2601234 -2601235 0 0 0 0 0 0 0 0 0 0  r:161109 l:2762343 10/15 12:41:21:468
s1=0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2601234 0 0 0 0 0 0 0 0 0 0 0  r:2762343 l:161108 10/15 12:38:30:489
DCC0
s0=0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2601234 0 0 0 0 0 0 0 0 0 0 0  r:2762343 l:161108 10/15 12:38:30:489
DCC2
s0=0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 154 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  r:667018 l:666863 10/15 12:16:51:819
Re: Out of sequence packets... Received the -ve icon
There is no longer any need to report on seq errors or out of order packets. As far as anyone can determine, the UDP protocol stack is as optimized as it can be. UDP is a lossy protocol, and the Windows UDP protocol stack sometimes gets weird about things, too. There will always be a low error rate.
I've turned off the seq error reporting feature in the settings myself.
