Thetis v2.8.11 ANF button issue
w2gs
Post by w2gs »
I installed the latest version of Thetis this afternoon. I am using an Anan 7000DLE MKII and an Anan 8000DLE. The ANF button does not function on either radio. Each radio has its own .xml file and is started with its own Icon and database file.
On the A8K the ANF button on RX1 is green and the lettering is greyed out; clicking the button does not change its status. When RX2 is started the button is black and the lettering is white and clicking the button turns it green and appears to function.
On the A7K the ANF button on RX1 is black and the lettering is greyed out; clicking the button does not change its status. When RX2 is started the button is black and the lettering is white and clicking the button turns it green and appears to function.
I didn't have the issue with v2.8.9. Any thoughts on this problem?
73, George
W2GS
GW0DQW
Re: Thetis v2.8.11 ANF button issue
Post by GW0DQW »
Hello George,
No such issues here , its there and illuminates when selected.
Regards
Chris
GW0DQW
w2gs
Post by w2gs »
Hi Chris,
This is a strange one. I can reset the database and it will work for a while then I notice it is greyed out again. Also I can switch to WWV and it works: switch back to the hambands and it's greyed out again. Will have to play with it and see what happens.
73, George
W2GS
Unable to duplicate this with an 8000, Thetis 2.8.11 and Protocol 2. This works fine on both 32 bit and 64 bit builds.
