ANAN-200D No connection
Dima
Post by Dima »
I need help with my ANAN200D network issue .
After attempt to download new firmware I lost connection between ANAD and pc.
I still able to read radio IP address and download firmware to radio with bootloader when jumper is on.
I try to connect radio directrly and via dhcp router
Network on windows 10 setup to private and metric it assign manually
Any thoughts what I am missing and what can be next step ?
Thank you for help
FM5GB
Re: ANAN-200D No connection
Post by FM5GB »
Hi Dima
Try to assign a correct IP address in bootloader. Sometimes an old IP adress is kept in the FPGA memory and that makes it impossible
for Thetis to find the radio while bootloader is still seeing it.
Hope this is the trick.
73s Phil FM5GB
