TIP: How to reduce ASIO latency on internal sound cards for better VAC operation
ea3aqr
Post by ea3aqr »
15 days ago my Windows 10 forced an update from v.1903 to v.20H2 and the nightmare begun...
From a 100% rock solid system capable of runing VAC (through Sound Blaster ASIO drivers) at 3 ms In/ 4ms Out without over/underflows, the system became totally unstable below 40-50 ms.
It was the begining of a 14 days fight against my OS.
I've read hundreds of pages and documents and tested all the options/tweaks suggested:
-Reinstall/update audio, video and lan drivers
-Upgrade/downgrade BIOS
-Tweak BIOS settings
-Tweak registry entries
-Changed Line based to MSI, IRQs...
-Installed a fresh OS (including v.1903 that worked before)
But unfortunately nothing worked...
Today, suspecting it was a problem with my ASIO driver buffer size, I started digging into it and found a small application:
http://www.djdecks.be/asioconfig.exe
And I was right... Windows or any driver update set my ASIO driver buffer to 50ms. :shock: :o
Changed it back to 2ms using the app and Voila! 4/5 ms ring buffers solid system again.
This post is just to help people with Creative and Realtek's cards who can't reduce his RingBuffer to a comfortable low level.
PS: English is not my languaje so, moderators, feel free to edit my post to make it more understandable.
rbduck
Re: TIP: How to reduce ASIO latency on internal sound cards for better VAC operation
Post by rbduck »
ea3aqr wrote:15 days ago my Windows 10 forced an update from v.1903 to v.20H2 and the nightmare begun...
Thank you for the information. Now I have a question or two.
When I start the app I see a list of drivers. I double click each one. The only driver that gave me the option to change the timing
was the Creative SoundBlaster AE-9 card. It was already at 6ms and I reduced it to 2ms. No other driver gave me an option to change
the timing. The remaining drivers brought up a box that stated, "Completed. If no dialog box popped up your ASIO Driver is not installed properly." Is this correct or do I have a problem? Is the Creative card the only driver timing one you changed?
Forgive me, I'm am always on the alert for any information that I can use to reduce latency. My Ringbuffer timing set to 30ms in and out.
In the past I have been able to set them at 5ms and be stable. Changing the AE-9 timing to 2ms did not improve anything.
This only works with certain ASIO drivers.
It does not appear to work with VB Audio (Voicemeeter, VB Cable) or Presonus drivers.
rbduck
Post by rbduck »
w-u-2-o wrote:This only works with certain ASIO drivers.
Gotcha. Thanks!
ea3aqr
Post by ea3aqr »
Yes, I can only change one of my listed drivers the "Creative SB/SBX series ASIO".
Your ASIO driver was set at 6ms, mine was at 50ms and that's a huge difference in latency.
ea3aqr
Post by ea3aqr »
I just can confirm that the APP works with Creative and Realtek's drivers, no other stuff to test with... :D
