W1JA wrote:rbduck wrote:W1JA wrote:Also, why does Thetis create a Thetis subdirectory in my Music folder? I delete it every time I notice it (it's always empty), and Thetis recreates it when it next starts up.
Recordings made by Thetis are stored there.
I have used the REC function from time to time, and Thetis (and I'm pretty sure PowerSDR before Thetis) doesn't put recordings in \Music\Thetis. I just made a test recording to be sure, and Thetis put the SDRQuickAudio.wav file in \Users\John\AppData\Roaming\OpenHPSDR\Thetis-x64. (I named the Thetis folder Thetis-x64 during the install.) I don't understand why my Thetis doesn't use \Music\Thetis as yours does, Ruben.
Anyway, this is a good time to mention how primitive and cumbersome this REC function behavior is, no matter where it saves the file. Ideally when each recording ends, the standard Windows dialog would appear, allowing the user to name the file (so the previous recording is not overwritten) and store it in a location of choice. So, I suppose this is not a bug report, but a feature request.
Inside Memory.cs constructor
if (!Directory.Exists(wave_folder))
// create PowerSDR audio folder if it does not exist
Directory.CreateDirectory(wave_folder);
Inside Wave.cs constructor
What is wave_folder we ask ousrselves....
- madness.jpg (54.49 KiB) Viewed 22243 times
and what gets placed in there? This....
- rec.jpg (21.24 KiB) Viewed 22239 times
