need help with mic level setting...
ON7WP
Post by ON7WP »
Running the latest update...
since the installer version, apparently I cannot set my mic level. Mic slider has no effect.
Master AF also not working. RX1AF OK
rest of thetis seems ok....
what I am doing wrong ? USB micro. VAC1 enabled.
Pedro ON7WP
Re: need help with mic level setting...
The main mic gain slider has no effect on VAC audio.
If using a USB microphone, be sure to go into the Windows sound control panel, advanced settings for your device, set it to 48KHz sampling rate, and adjust your level there. If you need more gain than Windows can provide, then adjust TX gain in the VAC settings.
