Master AF adjustement/saving for Monitoring CW
JJ4SDR
Post by JJ4SDR »
Is there a handy way to have the Master AF level saved for use when listening to the side-tone when on CW? I am sure there must be. It is really annoying when I get on CW (have a pair of head-phones plugged into the front of my ANAN 7000 DLE MKII) and the volume is WAY up for the side-tone. I can adjust the Master AF level on the fly of course, but would rather have the level saved.
I have only recently started using the radio on CW and the proper way of achieving what I am writing about above may be quite self-explanatory.
Best!
G3ZQH
Re: Master AF adjustement/saving for Monitoring CW
Post by G3ZQH »
Hi Juha
If you go to the Transmit tab in Setup you'll see' Monitor TX AF'. Set this value to the volume which suits you for CW sidetone. I use 6, but yours might be different.
73 Dave G3ZQH
JJ4SDR
Post by JJ4SDR »
Thanks very much Dave! Mine was at 66 :o
73 de Juha
(OH1HX)
The Master slider on the main UI will control this value when in TX. No need to drill down into the setup windows unless you want to.
JJ4SDR
Post by JJ4SDR »
w-u-2-o wrote:The Master slider on the main UI will control this value when in TX. No need to drill down into the setup windows unless you want to.
I realize that Scott but I don't like to have the side-tone blow my ear drums out when I don the cans and get on CW and much prefer that the level is set in anticipation of a bout of CW contacts :lol:
Just trying to help since Dave was directing you to the setup menu.
JJ4SDR
Post by JJ4SDR »
w-u-2-o wrote:Just trying to help since Dave was directing you to the setup menu.
I do appreciate it Scott!
