This may be an elementary question for most of you. I'm just now dipping my toe into digital modes. Using-WSJT-X, under Settings>Radio, What rig name do I use, Kenwood TS-2000 , Omnirig or Kenwood TS-2000? Am I even in the correct ballpark? I think I can figure the Port and Baud rate.
I see no Anan's on the list. Thanks!
WSJT-X configuration for 7000DLE Mk 4, blackWSJT-X configuration for 7000DLE Mk 4, black
Re: WSJT-X configuration for 7000DLE Mk 4, blackWSJT-X configuration for 7000DLE Mk 4, black
I use Kenwood TS-2000. I can't speak to how it works for split op's, but it works fine for everything else.
BTW, this is not specific to the 7000 or any other ANAN model number, but to Thetis.
And there is no "Mk4"
Gotcha. Thanks Scott!
There's also a PowerSDR entry which has a bit more capability but you're unlikely to notice any difference in WSJTX.
