With help from Richie and Ernst I now have JTDX running for CAT and PTT. Thanks guys
Hello Richie,
I use the TCI for log4om and tuner reminder with success but after an hour thetis shut down. Now when I try to connect something to the TCI server I get the following in the error log and thetis shutting down.
Entry : 3:20:37 PM Tuesday, February 15, 2022
Object reference not set to an instance of an object.
at Thetis.Console.OnTCIClientConnect()
at Thetis.TCPIPtciSocketListener.SocketListenerThreadStart()
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
73 Mike SV1JSO
73 Mike SV1JSO
Hello. I have the same error.
yes there will be a version later today that resolves that issue
*** updated test release 21k9pre8
A rework of some of the TCI server. Please try :
Download x64 [md5:3E0B3FB8CA895C3C6573D01F6DCB9C3E] - https://bit.ly/3uRXDVW
Thanks Richie.
[21k9pre8]
- rate limit added to TCI setup for outbound VFO/IF/DDS messages
- tci fixes and extra error checking
Thanks Richie.
[21k9pre8]
Thanks Richie, working fine here so far.
Thanks RIchie
In the same place here on K9 pre 8w2ner wrote:Screen Shot 2022-02-15 at 10.47.05 AM.pngRichie
Did you move the TCI settings off the user interface tab?
Thank you. Working
Thanks! TCI works!
And for RX2 there will be a СAT?
There is a full complement of CAT commands already implemented for RX2.Yevgeni wrote:Thanks! TCI works!
From a CAT perspective (not TCI) all the new IP port does is provide a separate mechanism for issuing CAT commands and receiving responses. Other than that it works identically to anything you can achieve using the serial CAT ports.
So did you really mean "When are TCI RX2 commands coming?"
Now I am working on 160 SSB. At this time, reception is on 80 m FT8, even at the time of my transmission on 160 m.
The communication log and the JTDX program are connected to Thetis via TCI.
Again, I may have made mistakes in this matter.
- SSB_FT8.jpg (762.34 KiB) Viewed 24795 times
rx2 support is still not fully supported. Hopefully over the next few days.
Problem. When communicating with TCI, JTDX does not work for transmission through VAC. Reception is working. When the settings are changed to CAT, transmission via VAC is resumed.
Do you have TCI-Audio enabled? That would not work. TCI-Audio is not implemented yet.RU6AI wrote:Problem. When communicating with TCI, JTDX does not work for transmission through VAC. Reception is working. When the settings are changed to CAT, transmission via VAC is resumed.
Activating TCI as transceiver interface (instead of OmniRig or hamlib) has no influence on the audio in/output.
https://www.oe3ide.com
No... Everything is the same.
- 111111.jpg (49.11 KiB) Viewed 24762 times
When I switch the transceiver control to TPI, the audio signal for transmission disappears. Everything is fine with the reception. As soon as I switch back to CAT, everything returns to normal. I don't change the AUDIO settings
yep make sure use tci audio is checked off, and you hit refresh to get the audio devices listed, then select suitable ones
That's exactly what I did .. I did not connect AUDIO TCI and did not change anything ..
vac is set correctly in Thetis? Mute the vac? gain level? rx1 af level ? Line 1 + Line 2 set the correct way around to match the in/outs?
Yes..When switching to CAT everything works fine.
cant explain it, works fine here. TCI audio off in JTDX, and audio devices set to match those in Thetis.RU6AI wrote:Yes..When switching to CAT everything works fine.
Ok. Most likely something local .. I have.
latest JTDX?RU6AI wrote:Ok. Most likely something local .. I have.
JTDX 2.2.158
Changed the VAC program. Did not help.
- 64.jpg (67 KiB) Viewed 24562 times
- 5.jpg (85.75 KiB) Viewed 24562 times
- 4.jpg (69.65 KiB) Viewed 24562 times
*** another day/hour, another test version - 21k9rc1
Moving on towards getting this at the the top of the thread. Please try :
Download x64 [md5:71BF4FDFE6912AA9D01A67DE5320A37A] - https://bit.ly/3GMUppa
Thanks, Richie.
[21k9rc1]
add: warnings added to setup-dsp if settings do not match. Remember, if a mode uses a different TX profile, that profile may have different dsp settings as well, causing additional dsp rebuild time
add: improvements to TCI. Should now be able to TX through RX2 in JTDX for example. Note: split op needs work on RX2, so use fake or none in jtdx if using RX2 as the tx
fix: mon now works for audio on vac2, and can also be volume adjusted. Still no vac mon when using vfob split on RX1
fix: recording playback when TX'ing can be mon volume adjusted. Recording playback when not tx'ing is RX volume
fix: TCI rate limit should now work as expected
Thanks, Richie.
[21k9rc1]
@RU6AI - I cant explain it. If you set the vac device in Thetis to headset/speakers do you hear ft8 signals? If all else fails. RX levels are up, mute is off, AGC level is ok etc etc, then back your database up and try a fresh one. Stranger things have happened.
just some ideas:TDX 2.2.158
* maybe you have enabled mute? (mute works now also on VAC)
* is it only rx or also tx
* do you get audio (power out) when pressing "Tune" in JTDX
* do you "see" audio going out in Voicemeeter when pressing "Tune" in JTDX
Yes .. The same is not clear. It shouldn't be, but for some reason it is. On a regular CAT, everything works properly. I will sort this out. Thank you.
