Release: AnanRecordingSaver
just made a tiny tool:
What does this tool?
1) copies SDRQuickAudio.wav (its always the latest audiofile from Thetis recording function) into your desired folder (prompt for target-filename)
2) opens the copied file in the audio editor of your choice
Via settings you can configure:
* Thetis-Datapath
* Path for QSO-Recordings
* open file after copying yes/no
* Path to audio editor
The program can also run in "silent" mode. Just start it with "ananrecordingsaver.exe -silent". In this case only the prompts are visible and program closes automatically after completion.
AnanRecordingSaver.zip
(10 KiB) Downloaded 290 times
