vk6cpu wrote:Thanks - your latest release 2.9.0.6 solved my problem!
What great service!!
Ciao
no problem Nigel, glad it is working again. Tdrv has been removed from the infoBar buttons. Fill has been added.
w9ac
Post by w9ac »
Thetis v2.9.0.6 corrected the problem. ZZZB now working in both display presentations.
Thank you!
Post by K9RX »
Forgive the dumb question: uninstall - does that mean if I want to try the new beta I will have to rebuild, entirely, my database? I customize a huge amount including lots of Appearance changes.
Also I'm seeing guys here in this thread that say they did not uninstall and it worked, kept DB... any harm in doing so?
K9RX wrote:Forgive the dumb question: uninstall - does that mean if I want to try the new beta I will have to rebuild, entirely, my database? I customize a huge amount including lots of Appearance changes.
no, the uninstall process does not touch your database
rbduck
Post by rbduck »
Is there a particular file or files that the PA calibration settings are saved in? I'm already saving and backing up the Thetis directory and everything in the c:\Users\user\AppData\Roaming\OpenHPSDR\Thetis-x64 directory.
rbduck wrote:Richie,
stored in databse.xml
rbduck
Post by rbduck »
I thought that may be the case. Just making sure. Thank you sir!
dl5tt
Post by dl5tt »
I tried to change the VFO step size from 2Hz to 5Hz in the appropriate tune_step_list (for my own version with modified diversity functions - just for fun) in file "console.cs" and I've got an error message in VS.
The errormessage says "variable infoBar wasn' t declared or not assigned". The pointer to the relevant source code line leads to this line 6510.
2022-04-24 18_22_24-Thetis_VS2022 - Microsoft Visual Studio.jpg (13.37 KiB) Viewed 25766 times
What is missing in my configuration?
I can compile the whole project, if I don't change anything in "console.cs" with the designer of VS.
But I can't open console.cs in the designer, because this error occurs and if I ignore this message, I can't compile the project.
My work arround is, to make my few changes with another editor and compile the project with VS without editing console.cs in VS.
But what can I do, to be able to edit "console.cs" with the designer in VS?
Perhaps you have a quick explanation / solution?
Thanks in advance
73 Josef
Dan
Re: Preparing for the next formal release of Thetis
Post by Dan »
the new PA settings and profiles are a incredibly useful feature, thank you.
Dan KM6CQ
alemrush
Post by alemrush »
Wants/Wishes
Include the Memories in the DB so if we export our DB the Memories will be ready for an import if needed after a PC format or other problems.
André
VA2WR
André / VA2WR
PD3LK
Post by PD3LK »
Include the Memories in the DB ....
Please keep it in a separate XML file but it would be handy if this file (incl the .bak) are moved to a Memories subdirectory under c:\Users\user\AppData\Roaming\OpenHPSDR\Thetis-x64. So it's more easy to backup the whole Thetis directory and it's sub directories.
r/Leon
Wants/Wishes
Option to auto-reset the VAC Under/Overflow counters in the VAC Settings when clicking/resetting the VAC Under/Overflow indicator on the console.
K1LSB wrote:Wants/Wishes
You can set them so they fade away. In that mode they will only momentarily show when the overflow/unerflow count increments. The other mode they hide when you click them, only to show again when the over/under increments. Not sure I see any gain from clearing the under/over number tbh.
Leaving this unchecked will cause them to fade away...
The gain is that I wouldn't need to manually go in and clear the indicators and counters individually. IMO it would be more streamlined/elegant to at least have the option to reset the counters and indicators with a single click.
tok2010
Post by tok2010 »
Thank you for your update of v2.9.0.6.
I tested it with Alex using my Hermes(TAPR) board.
Unfortunately Alex is not working with v2.9.0.6. On the contrary, Alex is fine with v2.8.11.
Please look at the pictures. When RX, Alex filter functions as for LPF, not BPF. You see the difference.
If there is some trick of setting up, please let us know. My settings of v2.9.0.6 are shown also in the attached pictures including the firmware
Tokio
JA1CCA
Alex RX 7MHz v2.9.0.6.JPG (2.18 MiB) Viewed 25182 times
Alex RX 7MHz v2.8.11.JPG (2.15 MiB) Viewed 25182 times
hermes 3.PNG (117.09 KiB) Viewed 25182 times
What happens if you uncheck Bypass?
tok2010
Post by tok2010 »
Thank you for advice. I neglected unchecking Bypass. Now it works.
Thank you again!
Tokio
N9HLL
Post by N9HLL »
First off..THANK YOU ! for what you have done, this is just amazing work.
A WANTWISH for you
Is it possible to add Drive level per mode ? IE: Different Drive requirements for AM vs SSB or various digital modes
It may be way more complicated than it is worth code wise but I wanted to ask.
Again Thank you so much for a fantastic piece of software
Rick (N9HLL)
3630 eSSB
Work in progress on the new meter system ;) Still loads and loads to do, at least 2-3-4-5-6 weeks away (as long as it takes). The directX surfaces are just floating there at the moment whilst developing. They will eventually move to another window, and may also sit in the main UI.
  • DirectX surfaces
  • Fully scalable
  • Multiple meters each with multiple meter items, with Rx, Mox, Tun, 2Tone specific layouts
  • Meter items source every bit of data available, from the regular meters that we are used to, to pbsnr, pa data, cpu, etc etc
  • Meter items can be overlaid. The needle meters are showing avg_signal (yellow) and signal (red) on top of each other
  • Meter items can have own refresh/update rates
  • Adjustable attack/decay rates
  • Image/png support for backgrounds, and other elements
  • Fully user configured (either xml, or interactive editor, tbd)
  • Z-order system
  • much to do !
RX1 and RX2 are shown in the attachment and the video. Top bar is signal, then avg_signal under it, followed by adc_l + adc_r. The top two bars and the needles are rendering at 60fps, the ADC bars are at 10fps.
Short vid : https://youtu.be/wpazWNoUsNM
73 Richie.
Yevgeni
Post by Yevgeni »
Hi
The WB level is not correct. So it should be or not.
The WB display has only enough code behind it to just barely show that the WB data stream coming from the firmware works. Do not expect very much from it at this time.
While the WB display is therefore ripe for many improvements, also remember that the preselector, any antenna tuners, and the antenna itself, will all have significant effects on the data displayed. This may or may not impact its usefulness depending upon the situation.
Yevgeni
Post by Yevgeni »
Thanks a lot.
This review is very helpful.
It is clear that you need to be able to directly connect a broadband antenna to view the entire spectrum.
Ernie
Re: Thetis v2.9.0 - Updates and Issues WANTWISH
Post by Ernie »
WANTWISH
1. I would like to see the "RXBYPASS on TX" checkbox available on the GUI instead of the setup screen. I (and others) have to check/uncheck regularly when going QRO.
2. I would like to see the "Play sound on expiry" button on the GUI so it would be easy to turn sound on/off on the 10 minute timer. Perhaps a speaker icon on the bottom strip next to the timer.
3. It would be helpful to have the SAM button cycle through the 3 SAM listen modes, LSB, USB. DSB. This would save having to open setup to switch different modes,
Thanks for all your work Richie
Ernie
W2FMU
WANTWISH
1) More space on GUI to add more buttons :D
rbduck
Post by rbduck »
ramdor wrote:WANTWISH
LOL! I was about to want/wish a button that could activate another bank of buttons I can include on my second monitor...Not really..
Thanks for ALL the effort Richie!
m1tzr
Post by m1tzr »
Richie I saw the post earlier asking the same question I had about the ability to save PA profiles per mode. After having played with it I think it might work better if there were tied to your TX profiles ?
Don't know if this would be easier to implement and not sure how TX profiles work with CW?
At least it wouldn't need another button :lol:
Looking forward to the new meters
Thanks as always
Paul
W2PA
Post by W2PA »
I wonder if everybody knows or remembers this GUI action (so it's probably worth mentioning):
Many controls on the main console can be right-clicked to bring you directly to the proper setup tab, making many of these changes easy.
Chris, W2PA
Ernie wrote:1. I would like to see the "RXBYPASS on TX" checkbox available on the GUI instead of the setup screen. I (and others) have to check/uncheck regularly when going QRO.
Why do you have to do this when QRO? The external coupler will work perfectly fine to feedback the output of the ANAN even though the amplifier is in standby.
Is simply stopping the timer not good enough? You do know you can left click the timer display to stop/start and right click it to reset, right?
rbduck wrote:LOL! I was about to want/wish a button that could activate another bank of buttons I can include on my second monitor...Not really..
A macro button strip or sub-window has already been on the wish list for some time.
By making them macro buttons, i.e. buttons you can simply type CAT strings into, they become all things to all people. Have as many buttons as you want, make them be whatever you want.
Where this gets fancy is to have
- buttons that display the state of a setting
- buttons that can toggle between two strings
- buttons that can send CAT strings out a serial port
Note that much this can be done in a vast array of existing macro software and other control surface solutions, such as Voicemeeter macros, DDUtil (older versions), Stream Deck, Matric, Bitfocus, and Touch Portal and too many others to list. But it would be nice to have a highly integrated version in Thetis. And to be able to import/export config's for those who are unwilling to learn CAT strings to borrow the work of others.
If you are really adventurous and willing to learn, the Node Red low code IoT programming environment is brilliant for this. But that takes a bit of study and effort.
Ernie
Post by Ernie »
I don't use an external coupler. I (and a few of us) have an RF-Kit amp with an internal coupler that does not give enough feedback when barefoot. I don't use an external coupler because I use all 4 antenna jacks on the amp.
I like to keep the timer running so I can see it, just enabling and disabling the sound as required. That way I still have the 10 minute timer available, I just have to look.
Locked
