Hi, Since I upgraded Thetis from 21K9 to v2.9.0.6, on all higher bands (17/15/12/10 meters) I see lot of spurs across the spectrum and "ADC overload" indicator keeps flashing while I increase the drive slider to Max 100. Reducing the drive slider would clear up the things. I even tried resetting the database with no luck. Then I reverted to 21K9 and all works absolutely fine. Any idea what's going on?
I am using Hermes Lite-2 (QRP 5 watts) transceiver.
Here is link to view the screen recording https://www.dropbox.com/t/qkdloomVQ0Bd21RU
Sid VU2YYF
Thetis and Hermes Lite
Since this forum is focused on Apache Labs hardware, answers might not be forthcoming because folks are not using/testing/developing with the Hermes Lite hardware. Have you asked the question on the Hermes Lite 2 forum/mail list/group/etc?vu3nxi wrote:Hi, Since I upgraded Thetis from 21K9 to v2.9.0.6, on all higher bands (17/15/12/10 meters) I see lot of spurs across the spectrum and "ADC overload" indicator keeps flashing while I increase the drive slider to Max 100. Reducing the drive slider would clear up the things. I even tried resetting the database with no luck. Then I reverted to 21K9 and all works absolutely fine. Any idea what's going on?
Sid VU2YYF
Sid,vu3nxi wrote:Hi, Since I upgraded Thetis from 21K9 to v2.9.0.6, on all higher bands (17/15/12/10 meters) I see lot of spurs across the spectrum and "ADC overload" indicator keeps flashing while I increase the drive slider to Max 100. Reducing the drive slider would clear up the things. I even tried resetting the database with no luck. Then I reverted to 21K9 and all works absolutely fine. Any idea what's going on?
Sid VU2YYF
The developer who makes some changes to Thetis to make it work correctly with the Hermes Lite 2 has not posted an update yet. If you try to use the one here it will not work correctly.
Post a question on the Google groups newsfeed. That will get you better results for Hermes Lite questions.
