Hi, before I go in hot and heavy and reload everything....has anyone had any issues with AM and SAM. Either I've done something silly with my setup but, when I decided to try and listen to an AM signal....no audio ditto SAM. DSB works as does everything else. And no output if I try and transmit. I'm running 7000 mkII with the latest thetis V2.9.0.6 and the latest P2 protocol. I am using Vac 1 for everything. Everything was working fine with the last version. I didn't try AM when I first upgraded to 2.9.0.6 so I can't be sure if it never worked or I have done something to beak it. Any thoughts ?
Regards Bob
Updates and Issues AM missing
Re: Thetis v2.9.0 - Updates and Issues AM missing
Go to Setup -> AudioVK4BXI wrote:Hi, before I go in hot and heavy and reload everything....has anyone had any issues with AM and SAM. Either I've done something silly with my setup but, when I decided to try and listen to an AM signal....no audio ditto SAM. DSB works as does everything else. And no output if I try and transmit. I'm running 7000 mkII with the latest thetis V2.9.0.6 and the latest P2 protocol. I am using Vac 1 for everything. Everything was working fine with the last version. I didn't try AM when I first upgraded to 2.9.0.6 so I can't be sure if it never worked or I have done something to beak it. Any thoughts ?
Regards Bob
Likely the transmit profile you are using for AM doesn't have the VAC device selected or the TX gain set up properly. Select all you need and then re-save the transmit profile.
Thanks I will try that
A quick fix, toggle the transmit profile to one that is working, save as "AM", set the bandwidth to say 5kHz and save again.VK4BXI wrote:Thanks I will try that
A bit ago some changes were made so transmit profiles are a bit more granular in the state that is kept, which is a good thing but it trips me up sometimes if making fast changes.
Re: Updates and Issues AM missing
Got it thanks !
Regards Bob
Regards Bob
