How do I enable Data Fill under Appearance inside Thetis. It is greyed out.
Update:
I can now choose different colors for the "Data Fill" /"RX Display" but nothing happens on the screen after applying the changes.
Data Fill
Re: Data Fill
Hello Juda,
Try unchecking Panadaptor Gradient on the lower right on that same page.
Re: Data Fill
Thanks. That did the trick and I can now choose colors, but the color change doesn't manifest itself on the screen
Re: Data Fill
Try moving the slider immediately to the right of the fill color selector box. That is the "alpha", or transparency, setting. If a slider is all the way to the left you will not see anything displayed, all the way to the right makes the color solid.
Re: Data Fill
Got it .....Under Display I need to check the "Fill Panadaptor" box too
