Gigabit Ethernet switch
hi
any recommendation on Gigabit Ethernet switch tp link ?
or any other
thank you elan ea5iwt/g0uut
or any other
vy 73
Elan EA5IWT/G0UUT
Elan EA5IWT/G0UUT
Re: Gigabit Ethernet switch
Recommendation is none.elan wrote:hi
or any other
Instead use a 2nd NIC for direct connention to radio.
greets Walter
I agree with Walter.
However, if you have your heart set on a switch, it will need to be an unmanaged switch in order to use Bootloader to load firmware. And even then, not all unmanaged switches will work properly.
If you do move forward with a switch, look for an unmanaged switch, in a metal case that can be added to your station ground, and be prepared to test Bootloader and return the switch if it will not pass Bootloader packets. If it can be powered off of the station 12VDC even better.
There's a million switches out there, but FWIW I've had good luck with the TP-Link TL-SG108 (not the 108e). It's got a metal case and it works with Bootloader. But I don't use it anymore since I've gone with a dedicated NIC for the radio.
hiw-u-2-o wrote:I agree with Walter.
so is it better to have gigabit network on the laptop ?
vy 73
Elan EA5IWT/G0UUT
Elan EA5IWT/G0UUT
so gigabit nic in laptop possibleDL2XY wrote:Recommendation is none.elan wrote:hi
or any other
greets Walter
many thanks
vy 73
Elan EA5IWT/G0UUT
Elan EA5IWT/G0UUT
If there is no actual NIC in the laptop a USB3.0 GigE NIC will work fine. USB2.0 will not support the full GiGE speed, so get a laptop with USB3.0 ports.
thank you so much sorry I was away for long and like now to order the 7000w-u-2-o wrote:If there is no actual NIC in the laptop a USB3.0 GigE NIC will work fine. USB2.0 will not support the full GiGE speed, so get a laptop with USB3.0 ports.
so my other question is what cable I need to do that one side usb 3 and to the Anan cat6?
thank you for great support
vy 73
Elan EA5IWT/G0UUT
Elan EA5IWT/G0UUT
You need a USB3.0 NIC and a standard Ethernet cable.
so as I understand I need USB 3.0 Ethernet Adapter is this correct and if so what one you can recommend pleasew-u-2-o wrote:You need a USB3.0 NIC and a standard Ethernet cable.
vy 73
Elan EA5IWT/G0UUT
Elan EA5IWT/G0UUT
You only need one if the laptop does not have a built-in GigE NIC, or if you need an extra one for your laptop. I have no specific recommendations.
hellow-u-2-o wrote:You only need one if the laptop does not have a built-in GigE NIC, or if you need an extra one for your laptop. I have no specific recommendations.
yes the one I will have will gigabit Nic
thank you kind for that info wow great support from you very quick
till later then
you doing top notch work I see that for years
vy 73
Elan EA5IWT/G0UUT
Elan EA5IWT/G0UUT
