"New Protocol" explained...
The "new protocol", aka Protocol 2, is a complete re-spin of the original firmware, with a new and substantially improved interface specification. You can find the specification well documented.
It implements Gigabit Ethernet (only--no support for 100BASE-T at all at the radio Ethernet connector). The higher speed of GigE is exploited to provide IF sample rates of up to 1.5Msps, with a much larger number of IF streams being simultaneously possible (limited by how many DDCs can fit in an FPGA, which has not changed). This latter improvement allows PureSignal to be used at any combination of sample rates. There are a lot of other "under the hood" improvements.
In order to use Protocol 2 you need a client that supports it. As of the time of this posting, that would be Thetis (basically PowerSDR modified to run the new protocol, plus a few other interesting features), SDR Console, and piHPSDR.
All of this is is late alpha/very early beta, and therefore is not recommended for the faint of heart ;) , nor those who are not comfortable with HPSDR Bootloader!
To move from Protocol 1 to Protocol 2 you can use either HPSDR Programmer or HPSDR Bootloader. To move from Protocol 2 to Protocol 1 you must use HPSDR Bootloader or the new Protocol 2 programmer.
I strongly recommend that you be comfortable and familiar with HPSDR Bootloader before making the leap. If you brick your radio with Protocol 2 firmware then HPSDR Bootloader will be the only way to reload firmware in your radio.
wv5k
Re: "New Protocol" explained...
Post by wv5k »
"Until such time as the New Protocol firmware goes into general release, all discussion will be concentrated here."
Nothing new posted in months. WU2O has implied elsewhere there may have been some positive developments recently with the timing issues. Can anyone make an informed comment?
Also, I see that GIT has v1.1 available for the 200D (Orion), same age as all the other versions (if not the same version #) there. Not to bust anyone's chops, but any real reason the 200D files weren't posted here, besides an oversight??
TIA,
Jim
WV5K
I've started an "update" thread so as not to crap up this thread with a bunch of random discussion about P2 status.
