No TX Monitor audio
K6JR
No TX Monitor audio
Post by K6JR »
I can not get any Monitor TX audio in Thetis. I have monitor on and the TX level turned up but no audio. I couldn't find a monitor position in the radio menu when operating it as a stand alone radio, no Thetis. What did I miss?
Tnx, Jim K6JR
K5WC
Re: No TX Monitor audio
Post by K5WC »
I just wired a mic yesterday for my G2, with it connected to the back mic 1/8th plug and MON on in Thetis I have audio coming out the speakers with a very slight delay. I just downloaded Thetis Monday for the very first time and most settings are still default.
73~John
K6JR
Post by K6JR »
Thanks John. Mine worked with a new download of 2.10.0 but when I added some Profiles in memory and then shut the program down when it came back on the tx monitor would not work. Very strange.
73, JR K6JR
K6JR wrote:Thanks John. Mine worked with a new download of 2.10.0 but when I added some Profiles in memory and then shut the program down when it came back on the tx monitor would not work. Very strange.
73, JR K6JR
I'm guessing there is no TX monitor function in piHPSDR (just a guess, I don't have it installed here).
In Thetis 2.10 it works fine here, but I'm using VAC exclusively. How are you listening on the G2, with the headphone or speaker jack?
Another test you might try, just to gather some more clues: does MON work when you use two-tone in Thetis, i.e. with MON on can you hear the transmitted two-tone signal?
BPerk
Post by BPerk »
I've been working with a new G2-100 using Thetis for two days. I don't have monitor audio using the headphones or the speaker jacks on the G2. I've not tried VAC.
KC2QMA
Post by KC2QMA »
Same here on G2-100W no panel, No Monitor audio with Thetis 2.10.0 with headphone or speaker outputs.
I also have other audio issues such as when I open RX2 there is no audio from RX2 until I stop and start Thetis.
Then when I close RX2 there is No audio from RX1 until I stop then start Thetis?
WT4DX
Post by WT4DX »
Is there a solution being formulated for the no TX monitor audio issue?
Tem
WT4DX
laurencebarker
Post by laurencebarker »
Yes there is. A very simple solution has been found but needs testing.
