Severe problem with PureSignal
Re: Severe problem with PureSignal
Yup, gonna do that next. I was even thinking I might swap a few of the internal jumper cables' respective positions (if cable length allows), that way if any cable is bad then something else in the rig's operation would likely also change (besides PS). ;)
Ernie
Post by Ernie »
When I bought my 7000dle new in 2017 it had a similar issue right out of the box. I sent it to Doug and he found a relay that did not have all its pins soldered. He fixed it and its been working great ever since.
W2FMU
So I finally got a block of free time this weekend and pulled the rig apart, swapped a couple of cables (probably not related to PS), checked all connections for tight and buttoned everything back together and fired it up.
No difference in PS behavior on 20 meters.
Even tried a brand new i9-13980HX laptop, same behavior.
Unless anyone has any other ideas, I'm almost forced to concede it's probably a hardware problem in the radio.
Sure sounds like it.
vk1hx
Post by vk1hx »
I'll take it...
73, Phil - VK1HX
W4WMT
Post by W4WMT »
Take what?
vk1hx
Post by vk1hx »
W4WMT wrote:Take what?
Hehe, Bryan.. I was preempting that if it might get tossed? I'd take it.. :)
73, Phil - VK1HX
I've contacted Doug, he said to send the radio to him, he's very interested in seeing what's going on.
Thanks for everyone's help,
Update: Doug found a bad PA final in my radio, he replaced both finals and PS is working fine now on all bands.
Here's PS on 20 meters at 41 watts, internal sampler (curves are very similar at any power):
Thanks to everyone in this thread who offered their assistance.
Great news! :)
ct1iqi
Post by ct1iqi »
as the difference between 20 m and the other bands is rather extreme, have you considered checking the filters that are in the transmit path? As a dummy load is used that would not discriminate between bands, nor does the firmware. But a faulty filter could, or a filter switch not happening and the wrong one being active.
Post by W1AEX »
I've been following your journey with this in the thread Mark and very glad that Doug was able to isolate the bad PA device as the issue. That's not a common point of failure with these rigs so you got bit by a rare one! We are very lucky to have Doug as our backstop for these issues when they come up.
