Installed and testing.
After intial setup and setting all bands configuration (mode, Zoom level, Filter setting, frequency position point). When switching bands it will take you to the last used frequency and mode etc which Thetis is open. However, when you close Thetis and relaunch it the same issue is back. It starts on the last band you were on when closing, but the Frequency is at the bottom of the band (Band Stack 1 values) Mode is CWU or CWL, and the corrosponding RX filter is 1.0k and the Zoom is set to 1x. It is the same result for all bands.
So it looks like the data (Band Stack) or something else is not saving/overwriting on Thetis exit.
EDIT: I think I've worked out what the casue of this is. Working with WD5Y's version of Thetis 2.10.1, I like to select both the Auto Save TX Profile options (refer to image below). What I did was untick those options and now Thetis is remembering which Band Stack I was on (freq, Band and Mode etc) after closing an reopening.
If you're havng the same issue, Thetis not remembering the last use freq etc, check if you are using the Auto save TX Profile option (under the Transmit Tab in Setup) and uncheck it and see if that corrects the issue. If not, try WD5Y's version of Thetis 2.10.1.
- Transmit.JPG (53.97 KiB) Viewed 18856 times
