piHPSDR - DL1YCF running on a PC
vk1hx
Postby vk1hx » Sun Nov 12, 2023 12:29 am
I'm still working through how to use Linux and piHPSDR so some of my terminology might be a little off.
I've setup a PC laptop (i7, 12Gb ram, 500gb SSD, dedicated graphics - GeForce GTX, touch screen etc) running Debian 11 Bullseye with Raspberry Pi desktop (so it all looks like the G2 with screen and knobs etc) see this link for the official Raspberry Pi image: https://www.raspberrypi.com/software/ra ... i-desktop/ with my ANAN 200D. running P2 firmware, connected directly to the laptop NIC.
I've followed the installation instructions from DL1YCF's manual (v3) and installed piHPSDR, easy enough and detects the ANAN 200D, the IP of the radio and Protocol. The issue I am having is the RX audio is "chopping" so to speak, its like a sh sh sh sh sound. I can see signals on the band etc but all audio is choppy. I am getting no sequencing errors.
What I did was change the ANAN 200D firmware from P2 back to P1 and issue resolved. RX audio is perfect. Is there something that I am missing in setting up the piHPSDR for P2? or I will have to stick with P1 firmware?
73, Phil - VK1HX
Re: piHPSDR - DL1YCF running on a PC
Postby w-u-2-o » Sun Nov 12, 2023 12:34 am
Does it work OK with Protocol 2 and Thetis?
vk1hx
Postby vk1hx » Sun Nov 12, 2023 2:42 am
w-u-2-o wrote:Does it work OK with Protocol 2 and Thetis?
Works perfectly with Thetis versions and P2.
73, Phil - VK1HX
AndrewK
Postby AndrewK » Sun Nov 12, 2023 11:39 am
Phil, piHPSDR v2.3 on a Mint 21.2 PC with 7000 & P2 audio is good.
Andrew
vk1hx
Postby vk1hx » Mon Nov 13, 2023 1:09 am
AndrewK wrote:Phil, piHPSDR v2.3 on a Mint 21.2 PC with 7000 & P2 audio is good.
Andrew
Thanks Andrew for your response. I'll give Mint 21.2 a run and see how it goes.
73, Phil - VK1HX
vk1hx
Postby vk1hx » Mon Nov 13, 2023 12:27 pm
Same issue with Linux Mint.
73, Phil - VK1HX
AndrewK
Postby AndrewK » Mon Nov 13, 2023 1:28 pm
I have piHPSDR on two Mint 21.2 PC's and both sound good.
The only difference that I have noticed is lower power output with the same mice gain compared to Thetis.
Postby w-u-2-o » Mon Nov 13, 2023 1:52 pm
Since it runs fine with Thetis (presumably on a different, Windows PC), and since others have having success with piHPSDR, that narrows it down to either:
- A problem with the NIC or NIC config. on the Linux PC (is it truly connecting at GigE speed?)
- A problem with Linux audio config
- A problem with how piHPSDR is being built.
Why not just run Thetis since a) it works and b) it has more functions and features?
Return to “piHPSDR”
