piHPSDR - DL1YCF running on a PC
									73, Phil - VK1HX
						Re: piHPSDR - DL1YCF running on a PC
Does it work OK with Protocol 2 and Thetis?
									73, Phil - VK1HX
Phil, piHPSDR v2.3 on a Mint 21.2 PC with 7000 & P2 audio is good.
Andrew
						Andrew
									73, Phil - VK1HX
									73, Phil - VK1HX
I have piHPSDR on two Mint 21.2 PC's and both sound good.
The only difference that I have noticed is lower power output with the same mice gain compared to Thetis.
Since it runs fine with Thetis (presumably on a different, Windows PC), and since others have having success with piHPSDR, that narrows it down to either:
- A problem with the NIC or NIC config. on the Linux PC (is it truly connecting at GigE speed?)
- A problem with Linux audio config
- A problem with how piHPSDR is being built.
Why not just run Thetis since a) it works and b) it has more functions and features?
