I use RX2 to listen to my audio for setting up and since updating to 2.10.3.4 pre release 5 no matter what i do i can not get my audio to be heard through RX2 , anyone else having this issue.
My other issue is that when using diversity i can not independently set my ATT on each receiver , as soon as diversity is engaged they boy just copy each other and for me its vital that i have independent control , this issue has been here for a while cant quite remember exactly which update it all changed....
Tony M0VDO
Anan 8000DLE MK2
RX2 issue 2.10.3.4 pre release 5
Re: RX2 issue 2.10.3.4 pre release 5
No seems to work fine here on pre 5. I assume you have checked Settings > General > RX2 and have Auto Mute RX2 on TX unchecked?
hi tony
the issue with no vac2 audio for rx2 when tx'ing on rx1 will be resolved for 2.10.3.4 pre-release-6 which will be released at some point. Still working on a few things.
regarding the att issue, do you have the same adc selected somewhere which will cause them to link? There might be some fixes required when diversity is used
cheers
cheers
DO2ZA Erwin
Hi All,
I have allso this ATT Problem, using 2 ADC the ATT Setup is linked when Diversity is aktiv.
I would prefer that the ATT is not linked, becouse my 2end Antenna is not so good and i have 10-20 db ATT on RX1, but not on RX2,
if I aktivate Diversity the ATTs are linked at the Moment.
73 Erwin
73 Erwin
Re: Thetis 2.10.3.4 pre release 5 - CPU Meter
V2.10.3.4 pr5 Win10 x64 protocol 2 installed and working fine on my ANAN 100B, except that there is no status bar CPU meter. Though not updating (stuck on 100%), it was there on my previous running release and did update on even earlier releases. The CPU meter's update rate is in settings>display>refresh rates. I have never noticed an disable/enable in any Thetis releases. Running the IK3BIG special skin, but no CPU meter in any of the other default skins.
which was?k6avp wrote:previous running release
option will be added to 2.10.3.4 pre-release-6 when released to stop this att linking when diversity in useDO2ZA Erwin wrote:Hi All,
73 Erwin
DO2ZA Erwin
Great news,
many thanks for your hard Work, Ritchie !!
73 Erwin
73 Erwin
pr6 now available Erwin, with the option in diversity form, and Tony tells me via FB that RX2 audio is resolved
https://github.com/ramdor/Thetis/releases
DO2ZA Erwin
Hi Ritchie,
yes, I installed yesterday Evening and it works good. Thanks.
73 Erwin
73 Erwin
