W4WMT wrote:m0cke wrote:So I have the M-Audio M-Track Solo and have installed the software
Using hostsample I get
driverCount = 5
ASIO4ALL v2
M-Track Solo and Duo ASIO
Voicemeeter AUX Virtual ASIO
Voicemeeter Insert Virtual ASIO
Voicemeeter Virtual ASIO
Press any key to continue . . .
Hi Jim,
Was that the only output from hostsample? No details shown for the M-Audio device?
The error code from debugview shows the driver didn't load, which usually means the device is not running, or another app has captured it.
Also, if you didn't get any output from hostsample about the M-Audio, that means it's not running, or another app has captured it.
As Ernst says above, Voicemeeter may have captured the driver, make sure Voicemeeter is not running.
Can you double check things
Bryan
Hi Brian
I've removed Voicemeeter and ASIO4ALL, now I just have the 1 ASIO device, hostsample shows this and can sucessfully start the device as seen below
driverCount = 1
ASIO driver: [0] = M-Track Solo and Duo ASIO
asioVersion: 2
driverVersion: 3501
Name: [M-Track Solo and Duo ASIO]
ErrorMessage: No ASIO Driver Error
ASIOGetChannels (inputs: 2, outputs: 2);
ASIOGetBufferSize (min: 16, max: 2048, preferred: 64, granularity: 16);
ASIOGetSampleRate (sampleRate: 44100.000000);
ASIOOutputReady(); - Supported
AsioCanReportOverload Not Supported
ASIOGetLatencies (input: 175, output: 174);
channel: 0 isInput: 1 isActive: 1 channelGroup: 0 type: 18 name: In 1
channel: 1 isInput: 1 isActive: 1 channelGroup: 0 type: 18 name: In 2
channel: 0 isInput: 0 isActive: 1 channelGroup: 0 type: 18 name: Out 1
channel: 1 isInput: 0 isActive: 1 channelGroup: 0 type: 18 name: Out 2
ASIO Driver started successfully.
- m-track.png (25.96 KiB) Viewed 30418 times
Closing hostsample the M-Audio device goes into Not Streaming
- standby.png (26.68 KiB) Viewed 30418 times
Regedit shows the correct device
- regedit.png (33.07 KiB) Viewed 30418 times
Now starting Thetis I still get the red CM and M-Audio is still in Not Streaming DeBugView shows it's initialising cmASIO
- thetis.png (183.19 KiB) Viewed 30418 times
- DeBugView.png (19.47 KiB) Viewed 30418 times
I'm really at a loss as i've reset the thetis database, just in case.
Hair getting thinner
Jim M0CKE
