Thetis not transmitting with WSJT-x
Miki
Post by Miki »
I had to reinstall my Thetis as I had done something and had no idea what I had done, so it was easier to perform a reinstall.
I have an issue where WSJT-x appears to send a carrier in Thetis but after an hour or so I check on pskreporter and I have not transmitted at all.
I have some screenshots but for the likes of me I am unable to see what is happening.
I did use the Measuring and adjusting guide at viewtopic.php?f=13&t=3574 before posting.. :)
I am hoping someone is able to help me, Thank You.
Weird carrier from WSJT-x
Wsjt-x modulation.jpg (694.43 KiB) Viewed 8001 times
Thetis Audio Settings
WSJT-x Audio Settings
Thetis Transmit Settings
WSJT-x COM Ports
WSJT-x COM Ports
Orban
Orban
w9mdb
Re: Thetis not transmitting with WSJT-x
Post by w9mdb »
What's your callsign? We can check other source for your transmissions.
Have you checked your time at http://time.is?
I checked VK5MN and whist rx'ing ok, no signals received by other stations for VK5MN
edit: I assume the 6w is getting out ;)
Miki
Post by Miki »
ramdor wrote:I checked VK5MN and whist rx'ing ok, no signals received by other stations for VK5MN
I thought I was getting out, but appears not too..
I have been trying for about 3 days now...
As you can see in the first pic, its a weird signal, if you call it that...
audio levels into thetis ok? what is the mic meter saying when it txs?
Miki
Post by Miki »
mic meter at -0.1dB
Screenshot attached..
that looks fine. Perhaps switch on DUP and see what the TX is like. Also use MON to 'hear' if it sounds ok. Only other thing is perhaps for some reason it is off frequency and outside the rx width of other stations?
Miki
Post by Miki »
It sounds like there are 2 tones, I have recorded it so you can blow your ear drums :lol: :lol: :lol: :lol:
DUP is on and MON does not do anything.
wsjt audio.mp3
(141.2 KiB) Downloaded 633 times
Please post screen shots of WSJT-X both receiving and transmitting.
Mike_N1JEZ
Post by Mike_N1JEZ »
It sounds to me like there are two signals in there very closely spaced...
Mike, N1JEZ
Mike, N1JEZ
w9mdb
Post by w9mdb »
In File/Settings/Advanced make sure you do NOT have Tone Spacing X2 or X4 checked.
w9mdb wrote:In File/Settings/Advanced make sure you do NOT have Tone Spacing X2 or X4 checked.
yeah that is probably it Mike ! the audio does seem to be 100+hz of bandwidth
Miki
Post by Miki »
Mike_N1JEZ wrote:It sounds to me like there are two signals in there very closely spaced...
Mike, N1JEZ
Yes there seems to be..
Once I have done that, I can hear it through my speakers, I can even see my self in JTAlert,
It seems to be looping somewhere..
