G2 with face now using Thetis.
TonyBlight
Since using Thetis and an Audio Interface on my G2 with face all my echo issues have gone even tests on high power.Ive been able to use my RE-20 Studio mike and good clean ps signal and great reports of Audio while running amp.I had all sorts of problems with using the stand alone G2 with my mike plugged into the XLR with an echo when TX heard even at 50w.I am so happy Im over these issues and most happy to use Thetis and putting the radio at work.
Re: G2 with face now using Thetis.
Hi Tony,
What sort of audio interface are you using now on your G2?
Bryan W4WMT
Bryan W4WMT
TonyBlight
Hi Bryan its a Behringer UMC204HD U-Photia.Very happy with it.W4WMT wrote:Hi Tony,
Bryan W4WMT
Tony, is your G2 running Protocol-2?
73, Bryan W4WMT
73, Bryan W4WMT
Bryan,
I'm using a Presonus Studio 192 mobile audio interface with my G2 Front Panel. Works well as it did with my 7000 MK II DLE.
The application that runs on the pi to interface with Thetis is p2app I'm making a guess that is an acronym for protocol 2 application.
George / W7GES
George / W7GES
TonyBlight
Hi Bryan,yes Ive upgraded the latest software and P2App.The version Im using is Thetis,v2.101x 64(8/23/23)(FW v2.0.0 protocol 2).W4WMT wrote:Tony, is your G2 running Protocol-2?
73, Bryan W4WMT
Tony
Glad here I’m excited as I ordered G2 face(screen )
Looking forward using SENNHEISER e835 mic and SENNHEISER headset mic
I learned a lot reading this thread and post
Thank you
Naknek Ak
Thank you
Naknek Ak
Hi Tony,I’m wondering if you can get back to try to get the stand alone function going well.That radio does not act as a stand alone which is a big selling point for ops.Just curious.
73 Walter
73 Walter
Kj6gea
Can I use G2 face/screen model without internet as stand alone like my Flex 6600M
No internet is required to use any openHPSDR radio, from the original Hermes to the G2, plus related hardware like the Hermes Lite or TRX Duo.KL4QG wrote:Kj6gea
That said, perhaps you meant "without an external PC", which is a bit of a different question. Again, the answer to your question is "Yes". However, you will be restricted to using the piHPSDR client software as Thetis will not run on the embedded Raspberry Pi processor.
I never intended use a computer with G2 screen model
But yes question was do I need internet
But now that brings up new question I hear G2 has very good noise reduction -will that noise reduction system work as should without internet
Note by April 25 I will have E.Musk Starlink Wi-Fi in log cabin
As Always thanks for responding
Joe Naknek Ak KA2ZSD
Joe,
The Noise Reduction in PiHPSDR, ( the G2 front panel software) uses the same DSP code as Thetis. So, it will work the same. The only time you will have to have internet access will be when you need to update the radio's firmware and software.
The basic features in PiHPSDR are almost the same as Thetis. But, Thetis has many more options and features that PiHPSDR does not have. If you find out later on that you want those features, you can always connect a computer to the internet and download Thetis. Then, connect to your radio with a network cable and operate your radio from Thetis.
You will have many options available to you.
