I have received a new G2. Everything works fine except the following:
PTT works fine in PIHPSDR and SDR Console. However PTT does not work in Thetis. Mox will key up transmitter but PTT does not. Are there any settings that I might be missing in Thetis.
In General settings I have PTT enabled. See attached
No PTT using Thetis
Re: No PTT using Thetis
What do you have here?
73 de Ernst
P.S. You can use the menu "Finder" and enter PTT...so you will find all settings related to PTT.
73 de Ernst
https://www.oe3ide.com
laurencebarker
You haven't said how your mic is wired. As drawn, the PTT will be on the "ring" connector but should work.
You can test mic connections including PTT using the audiotest application - see the manual for details.
Laurence Barker G8NJJ
Ernst
That was it.
Disable PTT was on. I looked at many settings but missed that one.
Appreciate the help.
Bob KC9RF
That was it.
Bob KC9RF
