Shipping Updates
Re: Shipping Updates
Oops ... I initially posted an earlier update ... not the current one. Here is the current update from Abhi:
Hi All,
I would like to provide a quick update on your ANAN G2-1K order.
The Factory has completed production of the Pallet Card, LPF, Filter/Control Boards. The enclosures have been delayed by the Chinese CM due to the Chinese New Year Holidays. The laser cutting and sheet metal work is complete, and the plates are now undergoing surface finishing and powder coating.
We expect to receive the enclosures in about 3 weeks after which the final assembly of the electronics will be completed followed by testing and burn-in after which we will commence shipments of the rig. We expect the final assembly and testing to take approximately 3 weeks after receipt of the enclosures.
We will commence invoicing your orders once it has completed the testing/burn-in. Orders will ship strictly in the order they were received.
I have had some queries regarding the enclosure dimensions, these are:
49.7cm L x 38.4cm W x 13.8cm H (not including extrusions/Handles)
The Product page has also been updated with the latest specs:
https://apache-labs.com/al-products/104 ... oking.html
We have also upgraded the LPF, this is now based on the design by DJ0ABR and is capable of high duty cycle operation without the need of active cooling, we use T200 size cores for 160/80/40/30/20M and 2mm Thick Copper wire coils for the higher bands.
I would like to apologise for the delay, however, we are quite confident that we will ship your orders as per the estimated ship time provided above without further delays.
Regards,
Abhi
Hi All,
Regards,
Abhi
ANAN 7000 DLE MKII
Thetis 2.10.3.11 x64 (7/17/25)
HP VICTUS (Gaming Laptop) - Intel Core i7 - 16GB memory - 512GB SSD - NVIDIA Graphics - WINDOWS 11
Best 73s,
WR4N - David
Best 73s,
WR4N - David
Hi Hi finial pa design probably still not done ! Moving shipping out 6 more weeks . Hopefully they will have a design by then . 1.5 kw would be nice but really all I wanted was 400-500 watts ,save a little tube life in the amp as 400 watts usually works pretty well for local talk other than 160 meters . Really making 100 boxes with heatsink should not take more than a few days . So I’m thinking there buying time again or design still not set in stone . Maybe a little more R&D . Anyway maybe by summer or it just might be Xmas .hihi
Thinking I should have bought a G2-100
oh 1kw of heat I’m thinking small fan ! Just think how hot a 100 watt radio gets !
Re: Shipping Updates G2 1K
Here's the response to questions I've asked Abhi which were asked in the community.
Hi Abhi,
Could you please clear up a few things?
These are questions that are coming from community.
First, it appears that we have now gone down from 1.5kW to 1kW (but the "description" and "specs" conflict with one another
Second, "without the need of active cooling." The update omits the mention of: "Noctua Fans for all cooling requirements."
Third, "Rack Mounting" when the width of 15.12"?
Jeffrey
Hello Jeffrey,
Thank you for your email. Kindly see below:
1. The power output is 1500W using two ART1K6 LDMOS devices, the LPF has also been upgraded as mentioned in my email earlier to be able to run at higher duty cycles. The model name is still the ANAN G2-1K.
2. “Without the need of active cooling” refers ONLY to the LPF. In most commercial designs manufacturers are using smaller toroidal cores in the LPF necessitating the need to actively cool them, since they heat up once they near saturation levels and cause the filter parameters to change! We are now using T200 sized toroids and 2mm thick copper air core inductors which do not require active cooling. Just to be clear there are still two 120mm Noctua fans dedicated to cooling the heatsink and a 40mm Noctua fan inside the PSU.
3. The G2-1K has never been marketed as a rackmount device, not sure where this is coming from?
Hope this helps.
Regards,
Abhi
Hi Abhi,
Jeffrey
Hello Jeffrey,
Hope this helps.
Regards,
Abhi
Checkout DJ0ABR website for most likely ruff design of LPF . Looks great.
I might’ve been law harsh about building the boxes as it does take a little time to make a heatsink area for the devices. And they probably wanted to look nice. 6 weeks still seems a long time . But maybe there’s only a few people working to assemble these things.
It looks like the LPF probably needs a little fine-tuning to the coils but anyway, let’s see what six Weeks spring us!
73 AC9PA
73 AC9PA
I believe this is coming from the picture shown on the main page. https://apache-labs.com/al-products/104 ... oking.html The picture clearly shows rack mount handles and rack mount ears on the transceiver.NY4JF wrote:Here's the response to questions I've asked Abhi which were asked in the community.
Hope this helps.
Regards,
Abhi
Abhi,NY4JF wrote:Here's the response to questions I've asked Abhi which were asked in the community.
Hi Abhi,
Jeffrey
Hello Jeffrey,
Hope this helps.
Regards,
Abhi
You wrote, "The G2-1K has never been marketed as a rackmount device, not sure where this is coming from?" Sir, both the Transceiver and the Amplifier pictures clearly show what appears to be "Rack Mounts." If not Rack Mounts, what purpose could they possibly serve? The appearance of these having Rack Mounts is why the assumption was made.
Thanks to you and the Team!
David
ANAN 7000 DLE MKII
Best 73s,
WR4N - David
Best 73s,
WR4N - David
That is really daft.
I thought so too, for obvious reasons and now I am confused.
The size is: 49.7cm L x 38.4cm W x 13.8cm H (not including extrusions)
Now looking at the box it kind of looks deeper than it is wide, so that would make the front panel 38,4 cm, which is too narrow for rack mount.
So now we need to make some adapters to make it fit in a rack. That is rather annoying.
I almost think they had a bunch of these lying around in China, that they made to the wrong specs.
Anyway, why o why haven't they just stuck it in a standard 19" rack housing??????? I bet these are readily available and much cheaper.
Jeffrey, I am sure that I speak for The Community when I say "THANK YOU" for facilitating the answers to some important questions! As we approach the 1 WEEK - "SHIPPING TO BEGIN" - COUNT-DOWN of the "Latest Update," I am going to send an Open Forum Post to ABHI. However, you seem to have his ear (so to speak) - so perhaps you could again work your magic and help facilitate the flow of communications? Specifically, will we again be disappointed or is there legitimate reason to hope that shipping will begin in around a week?NY4JF wrote:Here's the response to questions I've asked Abhi which were asked in the community.
Hi Abhi,
Jeffrey
Hello Jeffrey,
Hope this helps.
Regards,
Abhi
WITH GRATITUDE & 73,
David
WR4N
ANAN 7000 DLE MKII
Best 73s,
WR4N - David
Best 73s,
WR4N - David
ABHI, those like me, who began this purchase & journey in 2022, have experienced many, many delays. Nonetheless, there are those like me, who have extended even more faith & trust in A.L. by ordering the new Amplifier. Each time you provide any updates, we are grateful; regardless of the latest news, it certainly helps us to temper expectations.
Using the timeline of your most recent update, it appears that we are about 1 WEEK AWAY from shipments of the G2-1K (ANAN 1K5 or whatever the final name may be). PLEASE, again - PLEASE, would you provide us with the latest update? I am exceedingly hopeful that I may actually receive my Final Invoice soon & that my transceiver will ship soon. If you know there is going to be another delay, I believe we would all prefer to hear the news now rather than at a later date. As for me, I understand the many logistical challenges faced by A.L. But timely updates have been so helpful and greatly appreciated.
David
WR4N
David
WR4N
ANAN 7000 DLE MKII
Best 73s,
WR4N - David
Best 73s,
WR4N - David
How can I email Abhi directly ?
I’m going lite candle in church for everyone orders come true Sunday -
Have Blessed Weekend Everyone
Joe KA2ZSD Alaska
Joe KA2ZSD Alaska
Is that just one candle or a candle each one of us ! Hihi If the later you will need the air on in church even up there !
Dont really have a lot of hope . Just ordered a Hermes and going to use it with an old Drake R4C . Sold my Flex last week to a friend, probably should waited to sell the Flex but it’s no Anan . Had a 7000 when I first ordered the g2 -1k what ever one calls it figure the price of the 7000 would drop . So sold it the 7000 . Now that I ordered the Hermes it’s almost a sure thing that Anan will be shipping radios next week ! Anyway I’ll download the latest software and get the Hermes up and running . But I’ll be ready for that ghost radio.
Think that’s what we should call the radio ( Ghost Radio ) as it lives in spirit!
73 Everyone waiting.
AC9PA
AC9PA
We could use the extra heat in church
Lol
Lol
Just in case anyone didn’t notice, there is now a new and separate “TOPIC” for:
“ANAN G2 1K5 Shipping Update”
Abhi just posted an update there.
ANAN 7000 DLE MKII
Best 73s,
WR4N - David
Best 73s,
WR4N - David
I seen update
I also see he talks about power supply changes
Most 1500 watt amplifier in solid state amp use the voltage and wattage he talks about -looks they forget figure in 18-20 amps the radio using reason now they are going from 50-55 volts 70+ volts maybe more delays -
I’m still not happy that my last 6 emails from support not answered
I wish everyone luck on shipment of all products
I ordered the v2 controller over 2 years ago, on 14 April 2022, and I'm still waiting.
WU6R
Mark Wheeler
WU6R
Mark Wheeler
Mark WU6R
Looking for a shipping update for the Controller v2. Order with full payment made on 14 April 2022. I understand there has been a raspberry pi shortage for the controller v2, hoping the shortage is over and shipping has resumed for the controller v2.
WU6R
WU6R
Mark WU6R
Your best bet to get a response is to use the support email listed on the Apache Labs main website.WU6R wrote:Looking for a shipping update for the Controller v2. Order with full payment made on 14 April 2022. I understand there has been a raspberry pi shortage for the controller v2, hoping the shortage is over and shipping has resumed for the controller v2.
WU6R
It doesn't appear that they are building "controllers" anymore.
I ordered the Open HPSDR Hermes (14 bit ADC, EP3C25) Transceiver Card and the 10 watt Amplifier on April 13, 2023 and I have written Apache at least 30 times since. During 2023, they would answer and say, they would get back to me. Then in 2024, responses became less frequent and the last response was in June of 2024, saying they would check the production lime and write me back. Since then, I have written 20+ times and no response at all. I cannot understand how this company advertises and sells radios and yet, thye seem to have completely blown off customers for this product.
Has anyone received A shipment of the 14Bit board tranceiver or the amplifier. They have $588USD of my hard earned money. This (s turning inefficiency into neglect and approaching a dishonest racket, or It appears that way.to me.
Does snyone from Apache look at these forums?
They certainly do not answer emails.
73, Mike K9MB
73, Mike K9MB
I ordered an ANAN-10E (Revised) at the end of September and it got delivered from India within six weeks.
For me this is a good sign since I also ordered an ANAN-G2.
I only was willing to go through this process, because I did read a lot before placing those orders.
They used UPS as parcel service, they did their job very well.
The information in my Apache Labs account was a bit confusing and lagging behind reality.
As meantioned in my post before, I ordered an Anan-G2.
I placed the order in the end of September 2025.
In the early November I received an invoice, which I paid within 2 days.
Since I did not hear or read anything from Apache Labs for 4 weeks, I got nervous,
so I involved support@apache-labs.com.
Tony from Apache Labs replied within a week and gave me UPS Tracking information. At some point UPS came back to me via mail and asked for more information on the device. I responded in a short mail, stating the manufacturer, model name, unit price and intended usage. Then I was allowed to pay over 600€ import taxes.
It took approximatly 9 weeks from order to delivery and 5 weeks from invoice, payment and delivery.
As far as I can remember, the G2 was "in stock", when I placed the order.
I wish this procedure would have been a bit more transparent,
but of course I knew this could happen.
It has a Saturn Revision 2.1 board with FPGA Firmware V10, a CM4 module and a Sandisk Extreme 64GB microSD card.
Tsja your local government also wants a piece of the cake
