Anan G2, Can not mute mic
Can not mute mic button on dashboard. The slider will move but does not change mic level. I can adjust from setup, but not from dash panel. It has been OK last week, not now with no changes to Thetis version.
Re: Anan G2, Can not mute mic
Are you using the physical mic-input or VAC oder cmAsio?
73 de Ernst, OE3IDE
73 de Ernst, OE3IDE
https://www.oe3ide.com
When I tried setting up a headset mic, I also encountered this issue (mute doesn't do anything) in Thetis. The "Mic Gain" also didn't seem to change any of the transmit characteristics. I'm using the latest v2.10.3.6 x64 dev_3.
