Thetis Development Build 2.10.3.6 dev_7 available
I have just released dev_7 for 2.10.3.6.
There will likely be a few more development iterations before we finalise version 2.10.3.6. I plan to add some new meter types and further refine the IO features introduced in the dev_7 release before reaching a final state. Laurence is also working on additions for the new G2 larger screen models, which will be included in a later development stage. Enjoy experimenting with the new IO technology if it piques your curiosity.
I have made a few vids on the IO tech and they are probably worth a quick watch if you are interested.
https://youtu.be/oYRrm8YpD24
https://youtu.be/RfJ9pL-Ef8M
https://youtu.be/1LmUromJQNQ
Link to the release over on GitHub here : https://github.com/ramdor/Thetis/releas ... .3.6-dev_7
It is probably worth making a DB backup this time, as quite a bit is happening in there with the save/loading of this new I/O related data.
v2.10.3.6 Change Log - WIP dev_7
- [add] MultiMeterIO - get external data - use it in the MultiMeter system. Watch video : https://youtu.be/oYRrm8YpD24
- [add] new meter item, Rotator. Requires a data feed using the new Multi Meter io. : https://youtu.be/1LmUromJQNQ
- [change] can now have 20 multimeter containers
- [change] multimeter meter items are not limited. You can have unlimited in use at a time in a single container
- [change] midi micgain now is full range -40 to 10 (default mic gain)
- [change] midi comp is now full range 0-20
- [change] midi rit - now hold shift when turning for smaller change ~ -250 to 250
Re: Thetis Development Build 2.10.3.6 dev_7 available
Thanks as always Richie, look fwd to playing with the new meters.
I just need some clever person to point me in the right direction to get the info from my SPE 1.3 amp into the new meters.
Cheers
Paul
Cheers
Paul
Thanks a lot Richie, awesome!
Is it possible to add a variable for text for the QSO Timer counter?
@Gary, what would it be used by? At the moment it is just consumed by a Text Overlay. I could output text overlay text to the network io, or add it to the vfo output if its state is needed externally.
Just looking to put this in a text overlay block to make it more visible.
Hi Paul, there is an api doc for the expert spe's, but without one sat on the desk here it would be awkward to test/iterate. It needs some middle ware that takes the data and converts in to json/xml/raw (raw = : delimited pairs) and forwards it on to the new io system.m1tzr wrote:Thanks as always Richie, look fwd to playing with the new meters.
Cheers
Paul
As it happens I have built something that does just that for the Array Solutions Power Master I . I am waiting for them to send me the protocol docs for the PM2.
yes, np, i canNC3Z wrote:Just looking to put this in a text overlay block to make it more visible.
Richie, if possible, could you please add a command to center text that is shown in a text overlay?
Tnx
Tnx
I know I have said this before, and I will keep saying it
"THANK YOU" Richie!
"THANK YOU" Richie!
Thank you Richie.
73, Dan KM6CQ
73, Dan KM6CQ
How would I be able to use the new rotator function in Thetis to talk to my Hygain -EZ rotator control box?
It uses a com port on the PC. I am presently using DDUtil to control it.
Don W9BHI
Don W9BHI
invest in pstrotator, or wait for the tcpip client to be added to multimeter io. DDuitl has a tcpip server, and the rotator can be controlled via that.
ddutil docs...
GETROTOR - Gets Rotor position
Form: GETROTOR \r\n
Uses: GETROTOR\r\n
Rtrn: Head:045
ddutil docs...
Form: GETROTOR \r\n
Uses: GETROTOR\r\n
Rtrn: Head:045
I'll wait for the tcpip client.
Don W9BHI
Don W9BHI
Richie
Yesterday, while I was configuring my I/O meters, I was thinking that it would be very interesting to have an option to modify the text overlay based on the output of a variable.
This morning when I woke up I saw that you are already working on that option.
Now we can configure warnings based on high SWR, involuntary antenna changes, etc, etc...
Fantastic, you are the best!
Thank you very much
Thank you very much
Great work on the meters. Have you posted an update to the latest build. The link on GitHub goes to the older version of dev_7 without a selection for led indicators or the new rotator update. Also quick note that the background selection in rotators only selects the black background.
Thanks again.
73, George
W2GS
Thanks again.
73, George
W2GS
yes it is not ready for release yet George, and yep the background got left out from config in that version but is implemented now.
cheers.
cheers.
work continues. I am hoping to get a release done for the weekend, but some other stuff happening at the QTH this week so not much coding time.
Check this band selector out : https://youtu.be/ShlvXgug_qM
Cheers. R.
Cheers. R.
No audio in vid.
Thx
CL
Thx
CL
Carl Licari
NX5T
NX5T
i know, i gave it the silent treatment
It looks like this is the beginning of controls - not just meters - in containers, eventually allowing much more flexibility in configuring the console.
Is it possible (or will it become possible) to put the band selector in its own container?
Chris, W2PA
Chris, W2PA
Once the VFO module is completed with band, mode, and filter functionality, band/mode/filter will be implemented as separate modules. Users will be able to define the number of columns for button arrangements. Skin support is unlikely. This will allow users to position a band button box wherever they prefer. Eventually, we will introduce the capability to hide or remove legacy components. I anticipate that meters will gradually transition into more advanced meters and widgets.
Excellent! Thanks for the peek into the future of the main console. Looking forward to customizing the control layout.
Chris, W2PA
Chris, W2PA
Rchie,
Can you split VFO module into to separated modules, one for VFO A and another one for VFO B?
for those interested in checking out the new stuff early, a link to a dropbox build here :
https://www.dropbox.com/scl/fi/6pv2grll ... vpu83&dl=0
Title will say dev_8(wip5)
Note: if you have a vfo meter item in use, remove and re-add it.
v2.10.3.6 Change Log - WIP dev_8 (ongoing)
- [add] Led Indicator meter item - use variables in c# style code to provide a Boolean expression for the indicator eg %swr% > 2.0 or %split% == "SPLIT"
- [add] Added enable G2 panel; not enabled if Andromeda panel enabled and vice versa Added button actions for band selection - G8NJJ
- [add] ability to create default G2 settings - G8NJJ
- [add] band selector on the vfo display in multimeters. Just click the band text.
- [add] filter selector on the vfo display in multimeters. Just click the filter text
- [add] mode selector on the vfo display in multimeters. Just click the mode text
- [add] vfo display multimeter now allows changing by spinning the mouse wheel, and click to inc/dec, also keys can be pressed when digit highlighted.
- [change] Button actions processed more simply when G2 enabled (no shift action etc) - G8NJJ
When do you think the serial option will be added?
Thanks and keep up the great work!
Don W9BHI
Don W9BHI
Excellent stuff Richie, works like a charm!
Thank you vy much!
73 de Ernst, OE3IDE
Thank you vy much!
73 de Ernst, OE3IDE
https://www.oe3ide.com
It has occurred to me that a user could possibly end up putting a HUGE amount of work into building up a suite of multi meters, which would all get thrown away if he ever had to reset his database for any reason.
In that light, would it be possible for you to add an option to separately save the multi-meter settings into a separate file that could be reloaded after a database reset?
Mark,
In the mean time, the workaround for this is to make regular backup copies of your database, say daily or weekly. Then if you have to reset you can (after resetting) import an old one, going back until you find one that fixes your problem. You'd only lose settings changes made between the time of that particular backup and today.
Chris, W2PA
Chris, W2PA
