Hi All
Runing latest Thetis and 7000DLE MK2
I wanted to try and use a DVK built into DXLog for SSB Contest but when I activate VAC1 the mic thats plugged into the front of the Anan ceases to work.
is this normal operation?
Is there a work around other than running the audio through the PC?
TIA
Jim M0CKE
Can VAC1 be used with the hardware MIC?
Re: Can VAC1 be used with the hardware MIC?
In VAC setup have you checked the box "Allow PTT to override/bypass VAC for phone"?
No i'll check this at the weekend
Jim
Jim
