Thetis Development Build 2.10.3.6 dev_8 available
Re: Thetis Development Build 2.10.3.6 dev_8 available
reset your filters for RX2, by right clicking on the rx2 filters and select reset. You may have shifted the filter over and it now looks like USB?
Hello, reporting back after test. Yes, right mouse click of the 2.4K bandwidth filter>Reset to Defaults>Ok corrects the issue. Now the RX2 LSB works fine in the 40m and 80m bands.
Regards,
Stephen (W2WF)
Regards,
Stephen (W2WF)
yes, you had probably shifted it at some point. You can hold shift and drag a filter to the other sideband. This can be prevented if the option 'limit filter edges to sidebands' is ticked on in setup->filters
Thread locked. Please see the latest development release topic.
