First Install, 2.10.3.6 Crashes my PC
ViolinTeacher
Post by ViolinTeacher »
Install process seemed to go OK. But....
Thetis fully crashes and reboots the Dell laptop during the startup/FFT process.
Computer specs: Dell Inspiron 13 7000 - Ryzen 2700U, Radeon Vega Mobile Gfx 2.2GHz, 12GB ram installed. Running on windows 10 Home. 64 bit
I did check for any other running programs using task manager. There was the expected system anti-virus program listed, so I killed that before running the install.
Also tried compatibility test in Windows 8.
Several attempts, each one hard crashes causes a system reboot!
Any help appreciated!
73 de Bill Alpert/ KG6NRV
ViolinTeacher
Re: First Install, 2.10.3.6 Crashes my PC
Update: I uninstalled and reinstalled the software and this time it's running! Yay!
I noticed that it has a default profile for Hermes. Do I need to make a new profile or database for the Anan 7000?
Trucker
Post by Trucker »
Yes, there should be a drop down selection box that allows you to select your radio. But, you will still have to adjust the transmit and PA settings.
