I cant find the secret to getting the O/C outputs at the DB9 to switch at the same frequencies as the lpf's internal to the 7K. Im sure I could do this with node-red etc but it would sure be nice to just plug the db9 into my external amp`s lpf board. It would currently work fine for hambands only but I need to go slightly outside the defined bands for CFARS/MARS. I am doubtless missing something obvious
Ross ve6ars
O/C outputs tracking 7Kmk2 lpf's
ve6ars@gmail.com
Re: O/C outputs tracking 7Kmk2 lpf's
See this topic: viewtopic.php?f=46&t=4507&p=23384
Please continue the discussion in that topic if you need more help getting things to work.
