G2 - How to Create a NEW microSD card image
StephenAE2S
Post by StephenAE2S »
I have recently upgraded my Anan G2 to a Raspberry Pi Compute Module 5 with 8GB of RAM. There were no readily available images for the new system, so I created one.
While reading posts in this forum, I read where G2 owners were asking for step-by-step procedures for updating/upgrading their radios.
I hope folks find this procedure useful.
The attached procedure can be used for either the CM4 or the CM5 version of Raspberry Pi.
It was designed for the BlackFace with no display.
Since I do not have a G2 with a display screen, I cannot give instructions on how to set that part up. However, all steps and procedures are applicable to all Anan G2 radios. I HIGHLY RECOMMEND using the latest and greatest 64-Bit version of the Raspberry Pi OS, it’s called Bookworm at the time of this writing.
Stephen - AE2S
Creating a NEW microSD card for the ANAN G2.pdf
(1.13 MiB) Downloaded 209 times
KD1GA
Re: G2 - How to Create a NEW microSD card image
Post by KD1GA »
Thanks so much for posting this. My attempts to date haven’t gone well. Now I have a nice weekend project and can hopefully put the screws back in the cover after one. Vin KD1GA.
Vin KD1GA
Roger GT
Post by Roger GT »
Great job, Stephen!
It would be great to find another Expert to expand these instructions to include the G2 with Display and the G2 Ultra.
Vy 73 Roger DL2YDP
KD1GA
Post by KD1GA »
Hi Stephen,
I have an I/O board can i simply image, download and compile everything on the I/O board or does it have to be in the G2 like you have layed it out. Thanks again for helping out with this. Vin KD1GA
Vin KD1GA
KD1GA
Post by KD1GA »
Finally got pi 5 module working with P2 app and black faced G2. But when i try to run the update script says no such directory. Any help would greatly appreciated.
pi@raspberrypi:~ $ ./github/Saturn/scripts/update-G2.sh
bash: ./github/Saturn/scripts/update-G2.sh: No such file or directory
pi@raspberrypi:~ $
Vin KD1GA
StephenAE2S
Browse into the directory using folder view and make sure the file is there.
KD1GA
Post by KD1GA »
Worked great on the second attempt, bookworm and a Pi 5 module Had to run a few scrips from Jerry to get the P2 app to run at start up and another script to get the LED on the power button to behave correctly. G2 is working great with Thetis. The only thing that is still an issue is utilizing my second NIC, but all working well with the G2 on the network through a dumb switch. I’m going to set up the second NIC to access the internet and see if that works and advise. Thanks all for the help. Pi 5 module really improves the desktop experience and seems that P2 app is using less resources.
Vin KD1GA
